Saltar al contenido principal
HP Envy X2-15-C001Dx Wi-Fi Card Replacement
Qué necesitas
  1. HP Envy X2-15-C001Dx Wi-Fi Card Replacement, Back Panel: paso 1, imagen 1 de 1
    • Place the laptop face down on a table.
  2. HP Envy X2-15-C001Dx Wi-Fi Card Replacement: paso 2, imagen 1 de 2 HP Envy X2-15-C001Dx Wi-Fi Card Replacement: paso 2, imagen 2 de 2
    • Lift up the back stand.
  3. HP Envy X2-15-C001Dx Wi-Fi Card Replacement: paso 3, imagen 1 de 2 HP Envy X2-15-C001Dx Wi-Fi Card Replacement: paso 3, imagen 2 de 2
    • Remove the five screws from the bottom of the back plate using a Phillips #1 screwdriver.
  4. HP Envy X2-15-C001Dx Wi-Fi Card Replacement: paso 4, imagen 1 de 1
    • Remove four screws from the back stand hinges using a Phillips #1 screwdriver.
  5. HP Envy X2-15-C001Dx Wi-Fi Card Replacement: paso 5, imagen 1 de 2 HP Envy X2-15-C001Dx Wi-Fi Card Replacement: paso 5, imagen 2 de 2
    • Remove the hinges and the back stand from the laptop.
  6. HP Envy X2-15-C001Dx Wi-Fi Card Replacement: paso 6, imagen 1 de 1
    • Use a spudger to remove the thin panel where the back stand was.
  7. HP Envy X2-15-C001Dx Wi-Fi Card Replacement: paso 7, imagen 1 de 1
    • Remove the screws from the back panel using a Phillips #1 screwdriver.
  8. HP Envy X2-15-C001Dx Wi-Fi Card Replacement: paso 8, imagen 1 de 2 HP Envy X2-15-C001Dx Wi-Fi Card Replacement: paso 8, imagen 2 de 2
    • Remove two side screws using a Phillips #1 screwdriver.
  9. HP Envy X2-15-C001Dx Wi-Fi Card Replacement: paso 9, imagen 1 de 2 HP Envy X2-15-C001Dx Wi-Fi Card Replacement: paso 9, imagen 2 de 2
    • Pry apart the base from the screen by going around the entire perimeter with an opening tool.
  10. HP Envy X2-15-C001Dx Wi-Fi Card Replacement: paso 10, imagen 1 de 2 HP Envy X2-15-C001Dx Wi-Fi Card Replacement: paso 10, imagen 2 de 2
    • Remove the back panel from the laptop.
  11. HP Envy X2-15-C001Dx Wi-Fi Card Replacement, Wi-Fi Card: paso 11, imagen 1 de 1
    • Remove the screw holding the Wi-Fi card using a Phillips #1 screwdriver.
  12. HP Envy X2-15-C001Dx Wi-Fi Card Replacement: paso 12, imagen 1 de 1
    Herramienta utilizada en este paso:
    • Disconnect the white coaxial cable connected to the Wi-Fi card using a pair of tweezers.
  13. HP Envy X2-15-C001Dx Wi-Fi Card Replacement: paso 13, imagen 1 de 1
    • Disconnect the black coaxial cable connected to the Wi-Fi card using a pair of tweezers.
  14. HP Envy X2-15-C001Dx Wi-Fi Card Replacement: paso 14, imagen 1 de 1
    • Pull out the Wi-Fi card out of its slot to remove it from the laptop.
Conclusión
Una persona más ha completado esta guía.
Equipo
UMass Dartmouth, Team 2-6, Sinclaire Fall 2021 Miembro de UMass Dartmouth, Team 2-6, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S2G6
Miembros de 3
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 103
