Saltar al contenido principal
HP Envy Ultrabook 4-1043cl Battery Replacement
Qué necesitas
  1. HP Envy Ultrabook 4-1043cl Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Flip the laptop over so the bottom is facing you.
  2. HP Envy Ultrabook 4-1043cl Battery Replacement: paso 2, imagen 1 de 2 HP Envy Ultrabook 4-1043cl Battery Replacement: paso 2, imagen 2 de 2
    • Remove twelve 7.5 mm screws by using the Phillips #00 screwdriver.
  3. HP Envy Ultrabook 4-1043cl Battery Replacement: paso 3, imagen 1 de 1
    • Use plastic opening tool to remove the back cover.
    • You might want to remove it slowly and gently because the back cover is very thin and fragile.
  4. HP Envy Ultrabook 4-1043cl Battery Replacement: paso 4, imagen 1 de 2 HP Envy Ultrabook 4-1043cl Battery Replacement: paso 4, imagen 2 de 2
    • Remove three 4.2mm screws by using the Phillips #00 screwdriver.
  5. HP Envy Ultrabook 4-1043cl Battery Replacement: paso 5, imagen 1 de 2 HP Envy Ultrabook 4-1043cl Battery Replacement: paso 5, imagen 2 de 2
    • Disconnect the battery cable from the motherboard and remove the battery from the device.
Linea de Meta
4 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 12
Todo El Tiempo: 743
