HP Envy Ultrabook 4-1015dx Screen Replacement
Introducción
Ir al paso 1Use this guide to replace the broken display on your HP Envy Ultrabook 4-1015dx.
Qué necesitas
Make sure that the device is turned off and that all external devices are removed.
Using a size 0 Phillips head screwdriver, remove the four 3 mm size 0 screws attaching the hard drive casing to the device.
After removing the hard drive, you now must remove the motherboard. Start by pulling out the ribbon cable that attaches the touch pad to the motherboard.
On the bottom corners of the screen are two plastic covers. Pry these off using the plastic spudger
Remove the two 3 mm size 0 Phillips screws on the left and right.
2 personas más completaron esta guía.
