Saltar al contenido principal
HP Envy Ultrabook 4-1015dx Cooling Fan Replacement
Qué necesitas
  1. HP Envy Ultrabook 4-1015dx Cooling Fan Replacement, Battery: paso 1, imagen 1 de 1
    • Make sure that the device is turned off and that all external devices are removed.
  2. HP Envy Ultrabook 4-1015dx Cooling Fan Replacement: paso 2, imagen 1 de 1
    • Flip the device over so that the back plate is facing upwards.
  3. HP Envy Ultrabook 4-1015dx Cooling Fan Replacement: paso 3, imagen 1 de 2 HP Envy Ultrabook 4-1015dx Cooling Fan Replacement: paso 3, imagen 2 de 2
    • Using a small (size 0) Phillips head screwdriver, remove the twelve 5.5 mm external Phillips head screws that connect the back plate to the device.
    • Make sure to set the screws aside in a safe place so that you do not lose them, as they will be needed to reattach the backplate later.
  4. HP Envy Ultrabook 4-1015dx Cooling Fan Replacement: paso 4, imagen 1 de 2 HP Envy Ultrabook 4-1015dx Cooling Fan Replacement: paso 4, imagen 2 de 2
    • Using the plastic opening tool, gently pry off the back plate from the device.
  5. HP Envy Ultrabook 4-1015dx Cooling Fan Replacement: paso 5, imagen 1 de 2 HP Envy Ultrabook 4-1015dx Cooling Fan Replacement: paso 5, imagen 2 de 2
    • The large black box with the white warning images is the battery.
    • Move the ribbon cable so that it is no longer on top of the battery.
  6. HP Envy Ultrabook 4-1015dx Cooling Fan Replacement: paso 6, imagen 1 de 2 HP Envy Ultrabook 4-1015dx Cooling Fan Replacement: paso 6, imagen 2 de 2
    • Using a small (size 0) Phillips head screwdriver, remove the three 3.5 mm Phillips head internal screws that hold the battery in place.
    • Make sure not to lose these internal screws; they will later be used to reattach the battery.
  7. HP Envy Ultrabook 4-1015dx Cooling Fan Replacement: paso 7, imagen 1 de 2 HP Envy Ultrabook 4-1015dx Cooling Fan Replacement: paso 7, imagen 2 de 2
    • Lift up the battery and remove it from the slot as shown.
  8. HP Envy Ultrabook 4-1015dx Cooling Fan Replacement: paso 8, imagen 1 de 3 HP Envy Ultrabook 4-1015dx Cooling Fan Replacement: paso 8, imagen 2 de 3 HP Envy Ultrabook 4-1015dx Cooling Fan Replacement: paso 8, imagen 3 de 3
    • Use the plastic opening tool to disconnect the battery cable.
  9. HP Envy Ultrabook 4-1015dx Cooling Fan Replacement: paso 9, imagen 1 de 1
    • Lift up the battery and remove it from the device.
  10. HP Envy Ultrabook 4-1015dx Cooling Fan Replacement, Cooling Fan: paso 10, imagen 1 de 2 HP Envy Ultrabook 4-1015dx Cooling Fan Replacement, Cooling Fan: paso 10, imagen 2 de 2
    • Remove the screws that secure the top cover of the fan.
  11. HP Envy Ultrabook 4-1015dx Cooling Fan Replacement: paso 11, imagen 1 de 1
    • Lift the fan up and remove it gently.
  12. HP Envy Ultrabook 4-1015dx Cooling Fan Replacement: paso 12, imagen 1 de 1
    • Remove the fan cable with the plastic opening tool.
  13. HP Envy Ultrabook 4-1015dx Cooling Fan Replacement: paso 13, imagen 1 de 1
    • Remove the fan from the device.
Conclusión
Una persona más ha completado esta guía.
Eve Wyman
Miembro Desde 10/17/18
139 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 193
