Introducción
Removing and replacing the touch screen is an easy fix for a broken, scratched, or smudged touch screen that might have dead pixels as well.
Qué necesitas
Open the laptop.
Remove black tabs at bottom left and right corners and remove the two M2.5x2.5 screws behind the black tabs with the J0 screwdriver.
Flip hinges down and away from the rest of the panel.
Remove the four M2.5x2.5 screws with the J0 screwdriver.
Move 4 pieces of black tape across the bottom of the panel and any other accessory tape.
Disconnect the display cable connector that is located at the bottom right of the panel by pulling lightly.
2 personas más completaron esta guía.
