Saltar al contenido principal
HP Envy Touchsmart m6-k125dx Hard Drive Replacement
Qué necesitas
  1. HP Envy Touchsmart m6-k125dx Hard Drive Replacement, Back Panel: paso 1, imagen 1 de 2 HP Envy Touchsmart m6-k125dx Hard Drive Replacement, Back Panel: paso 1, imagen 2 de 2
    • Turn the laptop over so that the bottom is facing up
    • Using the J0 screwdriver, unscrew all 12 M2.5x5.5 screws from the back panel.
  2. HP Envy Touchsmart m6-k125dx Hard Drive Replacement: paso 2, imagen 1 de 1
    • Carefully remove the back panel to reveal the inner components.
  3. HP Envy Touchsmart m6-k125dx Hard Drive Replacement, Hard Drive: paso 3, imagen 1 de 3 HP Envy Touchsmart m6-k125dx Hard Drive Replacement, Hard Drive: paso 3, imagen 2 de 3 HP Envy Touchsmart m6-k125dx Hard Drive Replacement, Hard Drive: paso 3, imagen 3 de 3
    • Using the JIS screwdriver along with the J000 head, unscrew the four Phillips PM2.5x5.5 screws, and place them aside.
  4. HP Envy Touchsmart m6-k125dx Hard Drive Replacement: paso 4, imagen 1 de 1
    • Carefully detach the Hard Drive Adapter, and remove the Hard Drive from the laptop.
    • Make sure not to pull from the cord; pull from the head of the adapter.
Conclusión
4 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 6
Todo El Tiempo: 1,135
