Saltar al contenido principal
HP Envy TouchSmart m7 k010dx Battery Replacement
  1. HP Envy TouchSmart m7 k010dx Battery Replacement, Battery: paso 1, imagen 1 de 3 HP Envy TouchSmart m7 k010dx Battery Replacement, Battery: paso 1, imagen 2 de 3 HP Envy TouchSmart m7 k010dx Battery Replacement, Battery: paso 1, imagen 3 de 3
    • Turn your computer over so that the bottom is facing up.
    • Slide the left black switch towards center.
    • You should see an unlock image exposed to the left of switch if done correctly.
  2. HP Envy TouchSmart m7 k010dx Battery Replacement: paso 2, imagen 1 de 2 HP Envy TouchSmart m7 k010dx Battery Replacement: paso 2, imagen 2 de 2
    • Slide the right black switch towards center to release the battery.
  3. HP Envy TouchSmart m7 k010dx Battery Replacement: paso 3, imagen 1 de 2 HP Envy TouchSmart m7 k010dx Battery Replacement: paso 3, imagen 2 de 2
    • Pivot the loose edge of the battery closes to you by pushing it toward the back of the computer.
    • The battery should slide out freely.
    • If battery is not pivoted before sliding out, you risk breaking interlocking tabs on the battery or computer.
Conclusión
Una persona más ha completado esta guía.
Owen Ou
Miembro Desde 10/17/17
443 Reputación
4 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 723
