Introducción
If you observe a significant reduction in battery life, frequent charging, unexpected shutdowns, or visible physical damage, these may indicate that the battery in your HP Envy TouchSmart m7-k010dx needs replacement. The battery is a rechargeable lithium-ion type that allows you to maintain a sustainable energy flow as long as good maintenance and replacement is done.
Turn your computer over so that the bottom is facing up.
Slide the left black switch towards center.
You should see an unlock image exposed to the left of switch if done correctly.
Una persona más ha completado esta guía.
