Saltar al contenido principal
HP Envy TouchSmart 4-1215dx Motherboard Replacement
Qué necesitas
  1. HP Envy TouchSmart 4-1215dx Motherboard Replacement, Back Panel Assembly: paso 1, imagen 1 de 2 HP Envy TouchSmart 4-1215dx Motherboard Replacement, Back Panel Assembly: paso 1, imagen 2 de 2
    • Remove the thirteen Phillips #0 screws.
  2. HP Envy TouchSmart 4-1215dx Motherboard Replacement: paso 2, imagen 1 de 2 HP Envy TouchSmart 4-1215dx Motherboard Replacement: paso 2, imagen 2 de 2
    • Pull the panel up and off to remove from the laptop.
  3. HP Envy TouchSmart 4-1215dx Motherboard Replacement, Battery: paso 3, imagen 1 de 2 HP Envy TouchSmart 4-1215dx Motherboard Replacement, Battery: paso 3, imagen 2 de 2
    • Unplug the battery from the motherboard.
  4. HP Envy TouchSmart 4-1215dx Motherboard Replacement: paso 4, imagen 1 de 2 HP Envy TouchSmart 4-1215dx Motherboard Replacement: paso 4, imagen 2 de 2
    • Remove the three Phillips #0 screws from the battery.
    • Pull the battery out of the laptop.
  5. HP Envy TouchSmart 4-1215dx Motherboard Replacement, Fan: paso 5, imagen 1 de 1
    • Unplug the fan from the motherboard.
  6. HP Envy TouchSmart 4-1215dx Motherboard Replacement: paso 6, imagen 1 de 2 HP Envy TouchSmart 4-1215dx Motherboard Replacement: paso 6, imagen 2 de 2
    • Remove the four Phillips #0 screws holding in the fan.
    • Pull out the fan.
  7. HP Envy TouchSmart 4-1215dx Motherboard Replacement, Wi-Fi Card: paso 7, imagen 1 de 2 HP Envy TouchSmart 4-1215dx Motherboard Replacement, Wi-Fi Card: paso 7, imagen 2 de 2
    • Remove the single screw from the Wi-Fi card using a Phillips #0 screwdriver.
    • Pull the Wi-Fi card out of its slot.
  8. HP Envy TouchSmart 4-1215dx Motherboard Replacement, Heat Sink: paso 8, imagen 1 de 1
    • Remove four screws from the heat sink using a Phillips #0 screwdriver.
  9. HP Envy TouchSmart 4-1215dx Motherboard Replacement: paso 9, imagen 1 de 1
    • Gently lift the heat sink from the motherboard.
  10. HP Envy TouchSmart 4-1215dx Motherboard Replacement, Motherboard: paso 10, imagen 1 de 1
    • Remove the remaining from the motherboard with a Phillips #0 screwdriver.
  11. HP Envy TouchSmart 4-1215dx Motherboard Replacement: paso 11, imagen 1 de 3 HP Envy TouchSmart 4-1215dx Motherboard Replacement: paso 11, imagen 2 de 3 HP Envy TouchSmart 4-1215dx Motherboard Replacement: paso 11, imagen 3 de 3
    • Disconnect the remaining cables from the motherboard by gently tugging on the pull tabs or the edges of the connectors that sit in the terminals.
  12. HP Envy TouchSmart 4-1215dx Motherboard Replacement: paso 12, imagen 1 de 2 HP Envy TouchSmart 4-1215dx Motherboard Replacement: paso 12, imagen 2 de 2
    • Gently lift the motherboard from the housing to remove it from the laptop.
Conclusión
Cassie Hunter
Miembro Desde 02/08/22
97 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 11
Todo El Tiempo: 137
