Saltar al contenido principal
HP Envy TouchSmart 15 Solid State Drive Replacement
Qué necesitas
  1. HP Envy TouchSmart 15 Solid State Drive Replacement, Battery: paso 1, imagen 1 de 1
    • Press the battery release tab and the battery will pop up.
  2. HP Envy TouchSmart 15 Solid State Drive Replacement: paso 2, imagen 1 de 1
    • Remove the battery from the laptop, it will come out easily.
  3. HP Envy TouchSmart 15 Solid State Drive Replacement, Accessory Plate: paso 3, imagen 1 de 2 HP Envy TouchSmart 15 Solid State Drive Replacement, Accessory Plate: paso 3, imagen 2 de 2
    • Remove the single screw holding the accessory plate. This is a PH0 2.0x2.5 screw.
  4. HP Envy TouchSmart 15 Solid State Drive Replacement: paso 4, imagen 1 de 3 HP Envy TouchSmart 15 Solid State Drive Replacement: paso 4, imagen 2 de 3 HP Envy TouchSmart 15 Solid State Drive Replacement: paso 4, imagen 3 de 3
    • Pry the accessory plate up from the back of the laptop by applying force upwards where the screw was removed.
  5. HP Envy TouchSmart 15 Solid State Drive Replacement, Solid State Drive: paso 5, imagen 1 de 2 HP Envy TouchSmart 15 Solid State Drive Replacement, Solid State Drive: paso 5, imagen 2 de 2
    • Remove the PM 2.0x2.5 screw with the PH#0 Screwdriver attachment that is shown at the corner of the Solid State Drive.
    • After you have removed the screw, the Solid State Drive should lift up.
  6. HP Envy TouchSmart 15 Solid State Drive Replacement: paso 6, imagen 1 de 2 HP Envy TouchSmart 15 Solid State Drive Replacement: paso 6, imagen 2 de 2
    • Very carefully, remove the SSD by gently pulling away from the SSD socket.
Conclusión
4 personas más completaron esta guía.
Ramon Villadonga
Miembro Desde 09/04/15
1,029 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 2-6, Sullivan Fall 2015 Miembro de USF Tampa, Team 2-6, Sullivan Fall 2015
USFT-SULLIVAN-F15S2G6
4 Miembros
10 Guías creadas
2 comentarios
Please what type of ssd is that and can i get the specifications? I want to get one for my laptop since it didn’t ship with it. Its the same as the one above. HP ENVY TS 15 Notebook PC Thanks.
temidayoabayomizannu - Contestar
Wht type of ssd i can insert here
Plz help me
Kavindra Danushka Rajapaksha - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 16
Todo El Tiempo: 2,935
