Saltar al contenido principal
HP Envy TouchSmart 15 Hard Drive Replacement
Qué necesitas
  1. HP Envy TouchSmart 15 Hard Drive Replacement, Battery: paso 1, imagen 1 de 1
    • Press the battery release tab and the battery will pop up.
  2. HP Envy TouchSmart 15 Hard Drive Replacement: paso 2, imagen 1 de 1
    • Remove the battery from the laptop, it will come out easily.
  3. HP Envy TouchSmart 15 Hard Drive Replacement, Accessory Plate: paso 3, imagen 1 de 2 HP Envy TouchSmart 15 Hard Drive Replacement, Accessory Plate: paso 3, imagen 2 de 2
    • Remove the single screw holding the accessory plate. This is a PH0 2.0x2.5 screw.
  4. HP Envy TouchSmart 15 Hard Drive Replacement: paso 4, imagen 1 de 3 HP Envy TouchSmart 15 Hard Drive Replacement: paso 4, imagen 2 de 3 HP Envy TouchSmart 15 Hard Drive Replacement: paso 4, imagen 3 de 3
    • Pry the accessory plate up from the back of the laptop by applying force upwards where the screw was removed.
  5. HP Envy TouchSmart 15 Hard Drive Replacement, Hard Drive: paso 5, imagen 1 de 2 HP Envy TouchSmart 15 Hard Drive Replacement, Hard Drive: paso 5, imagen 2 de 2
    • Use the plastic opening tool to pry the hard drive away from the board. Notice that there is a slit centered at the back of where the hard drive is sitting. This is where you'll insert the plastic opening tool as shown in the photo. Finally, pry with the plastic opening tool to remove the hard drive.
  6. HP Envy TouchSmart 15 Hard Drive Replacement: paso 6, imagen 1 de 2 HP Envy TouchSmart 15 Hard Drive Replacement: paso 6, imagen 2 de 2
    • Firmly grasp the connector's base as shown and pull to remove from the hard drive.
Conclusión
11 personas más completaron esta guía.
Ramon Villadonga
Miembro Desde 09/04/15
1,029 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 2-6, Sullivan Fall 2015 Miembro de USF Tampa, Team 2-6, Sullivan Fall 2015
USFT-SULLIVAN-F15S2G6
4 Miembros
10 Guías creadas
6 comentarios
Thanks man! Worked great.
Charles Uibel - Contestar
Thank you! I was worried about the step to remove the accessory plate, but seeing this tutorial helped reassure me that I wasn't going to break it. Very interesting design choice by HP...
Rob Kachmar - Contestar
What’s the hard disk size in case I want to buy a replacement? In terms of inches. I see online that most of the laptop hard disks are quoted as 2.5 or 3 inch
Bwana Lawi - Contestar
2.5 inches. I fitted the Samsung 850 EVO, fits perfectly.
cbrowne91 - Contestar
Thanks found the guide helpful. However I caused myself a problem by breaking the black hdd retaining clip on the motherboard. It was so fragile that I’m sure this has happened to others???? Any repair ideas anyone? As you imagine I’d be grateful of a resolution.
Arthur David Mc Kee - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 6
Ultimos 30 días: 39
Todo El Tiempo: 12,655
