Saltar al contenido principal
HP Envy TouchSmart 15 CMOS Battery Replacement
Qué necesitas
  1. HP Envy TouchSmart 15 CMOS Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Press the battery release tab and the battery will pop up.
  2. HP Envy TouchSmart 15 CMOS Battery Replacement: paso 2, imagen 1 de 1
    • Remove the battery from the laptop, it will come out easily.
  3. HP Envy TouchSmart 15 CMOS Battery Replacement, Accessory Plate: paso 3, imagen 1 de 2 HP Envy TouchSmart 15 CMOS Battery Replacement, Accessory Plate: paso 3, imagen 2 de 2
    • Remove the single screw holding the accessory plate. This is a PH0 2.0x2.5 screw.
  4. HP Envy TouchSmart 15 CMOS Battery Replacement: paso 4, imagen 1 de 3 HP Envy TouchSmart 15 CMOS Battery Replacement: paso 4, imagen 2 de 3 HP Envy TouchSmart 15 CMOS Battery Replacement: paso 4, imagen 3 de 3
    • Pry the accessory plate up from the back of the laptop by applying force upwards where the screw was removed.
  5. HP Envy TouchSmart 15 CMOS Battery Replacement, CMOS Battery: paso 5, imagen 1 de 3 HP Envy TouchSmart 15 CMOS Battery Replacement, CMOS Battery: paso 5, imagen 2 de 3 HP Envy TouchSmart 15 CMOS Battery Replacement, CMOS Battery: paso 5, imagen 3 de 3
    • Remove the screw from the wireless adapter with a PH0 screwdriver then move the adapter out of the way to access the CMOS battery.
  6. HP Envy TouchSmart 15 CMOS Battery Replacement: paso 6, imagen 1 de 1
    • Use a plastic or metal spudger to release the CMOS battery from the clips.
  7. HP Envy TouchSmart 15 CMOS Battery Replacement: paso 7, imagen 1 de 2 HP Envy TouchSmart 15 CMOS Battery Replacement: paso 7, imagen 2 de 2
    • Remove the battery from the device.
Conclusión
Una persona más ha completado esta guía.
Robert Patterson
Miembro Desde 09/04/15
1,457 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 2-6, Sullivan Fall 2015 Miembro de USF Tampa, Team 2-6, Sullivan Fall 2015
USFT-SULLIVAN-F15S2G6
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 11
Todo El Tiempo: 7,825
