Saltar al contenido principal
HP Envy Sleekbook m6-k010dx LCD Replacement
Qué necesitas
  1. HP Envy Sleekbook m6-k010dx LCD Replacement, Battery: paso 1, imagen 1 de 1
    • Remove the twelve 9 mm Phillips #00 screws.
  2. HP Envy Sleekbook m6-k010dx LCD Replacement: paso 2, imagen 1 de 2 HP Envy Sleekbook m6-k010dx LCD Replacement: paso 2, imagen 2 de 2
    • Use the plastic opening tool and your hands to remove the bottom cover.
  3. HP Envy Sleekbook m6-k010dx LCD Replacement: paso 3, imagen 1 de 1
    • Disconnect the battery power cable from the motherboard.
  4. HP Envy Sleekbook m6-k010dx LCD Replacement: paso 4, imagen 1 de 1
    • Remove the six 6 mm Phillips #00 screws from the battery.
  5. HP Envy Sleekbook m6-k010dx LCD Replacement: paso 5, imagen 1 de 2 HP Envy Sleekbook m6-k010dx LCD Replacement: paso 5, imagen 2 de 2
    • Lift the battery out of the laptop.
  6. HP Envy Sleekbook m6-k010dx LCD Replacement, LCD: paso 6, imagen 1 de 2 HP Envy Sleekbook m6-k010dx LCD Replacement, LCD: paso 6, imagen 2 de 2
    • Remove the stickers from the bottom left and right corner of the device with a plastic opening tool.
  7. HP Envy Sleekbook m6-k010dx LCD Replacement: paso 7, imagen 1 de 1
    • Remove the two 2.5mm Phillips #00 screws found underneath the previously removed stickers.
  8. HP Envy Sleekbook m6-k010dx LCD Replacement: paso 8, imagen 1 de 3 HP Envy Sleekbook m6-k010dx LCD Replacement: paso 8, imagen 2 de 3 HP Envy Sleekbook m6-k010dx LCD Replacement: paso 8, imagen 3 de 3
    • Use the plastic opening tool to pry the bezel free from the LCD housing.
  9. HP Envy Sleekbook m6-k010dx LCD Replacement: paso 9, imagen 1 de 2 HP Envy Sleekbook m6-k010dx LCD Replacement: paso 9, imagen 2 de 2
    • Remove the four 2.5mm Phillips #00 screws located in each corner of the LCD screen.
  10. HP Envy Sleekbook m6-k010dx LCD Replacement: paso 10, imagen 1 de 2 HP Envy Sleekbook m6-k010dx LCD Replacement: paso 10, imagen 2 de 2
    • Use the plastic opening tool to remove the LCD screen from its housing.
    • Lay the LCD screen flat on the keyboard.
  11. HP Envy Sleekbook m6-k010dx LCD Replacement: paso 11, imagen 1 de 1
    • Disconnect the cable which connects the LCD to the motherboard.
    • Pul the LCD screen out.
Conclusión
2 personas más completaron esta guía.
codi whittaker
Miembro Desde 02/14/18
508 Reputación
3 Guías creadas
Equipo
USF Tampa, Team S1-G4, Nance Spring 2018 Miembro de USF Tampa, Team S1-G4, Nance Spring 2018
USFT-NANCE-S18S1G4
4 Miembros
15 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 5
Todo El Tiempo: 919
