Saltar al contenido principal
HP Envy M6-1205DX Touchpad Replacement
Qué necesitas
  1. HP Envy M6-1205DX Touchpad Replacement, Battery: paso 1, imagen 1 de 1
    • Lay the device face down to begin.
  2. HP Envy M6-1205DX Touchpad Replacement: paso 2, imagen 1 de 1
    • Slide the release mechanism to the left to release the battery.
  3. HP Envy M6-1205DX Touchpad Replacement: paso 3, imagen 1 de 2 HP Envy M6-1205DX Touchpad Replacement: paso 3, imagen 2 de 2
    • Remove the battery.
  4. HP Envy M6-1205DX Touchpad Replacement, Touchpad: paso 4, imagen 1 de 1
    • Using a Phillips #1, remove the 8 10.6mm screws.
    • Also using a Phillips #1, remove the 8.6mm screw.
  5. HP Envy M6-1205DX Touchpad Replacement: paso 5, imagen 1 de 1
    • Slide the center panel down to remove it.
  6. HP Envy M6-1205DX Touchpad Replacement: paso 6, imagen 1 de 1
    • Using a Phillips #1, remove the 3.5mm screw.
    • Our computer did not come with a hard drive so you should have one in the empty hole. We have marked where we believe the screws will be in orange.
    • Using a Phillips #1, remove the four 10.6mm screws.
  7. HP Envy M6-1205DX Touchpad Replacement: paso 7, imagen 1 de 1
    • Pull the disk drive out to remove it.
  8. HP Envy M6-1205DX Touchpad Replacement: paso 8, imagen 1 de 2 HP Envy M6-1205DX Touchpad Replacement: paso 8, imagen 2 de 2
    • Using a Phillips #1, remove the two 2.4mm screws.
  9. HP Envy M6-1205DX Touchpad Replacement: paso 9, imagen 1 de 2 HP Envy M6-1205DX Touchpad Replacement: paso 9, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Flip the black tab up on the clamp that holds the ribbon cable in place.
    • Pull the cable back with your fingers or a pair of tweezers.
  10. HP Envy M6-1205DX Touchpad Replacement: paso 10, imagen 1 de 2 HP Envy M6-1205DX Touchpad Replacement: paso 10, imagen 2 de 2
    • Flip the computer back over
    • Use the plastic opening tool to pry the keyboard up .
  11. HP Envy M6-1205DX Touchpad Replacement: paso 11, imagen 1 de 3 HP Envy M6-1205DX Touchpad Replacement: paso 11, imagen 2 de 3 HP Envy M6-1205DX Touchpad Replacement: paso 11, imagen 3 de 3
    • Carefully lift the keyboard up.
    • Flip up the black tab holding the large ribbon cable down.
    • Push both sides of the small white tab forward to release the small ribbon cable.
    • Pull both the cables out to remove them.
    • Remove the keyboard.
  12. HP Envy M6-1205DX Touchpad Replacement: paso 12, imagen 1 de 3 HP Envy M6-1205DX Touchpad Replacement: paso 12, imagen 2 de 3 HP Envy M6-1205DX Touchpad Replacement: paso 12, imagen 3 de 3
    • Flip the small white tab up to release the ribbon cable.
    • Pull to remove.
    • Repeat the same steps for the other cable.
  13. HP Envy M6-1205DX Touchpad Replacement: paso 13, imagen 1 de 1
    • Using a Phillips #1, remove the four 5.6mm silver screws.
  14. HP Envy M6-1205DX Touchpad Replacement: paso 14, imagen 1 de 2 HP Envy M6-1205DX Touchpad Replacement: paso 14, imagen 2 de 2
    • Use the plastic opening tool to pry the face plate off the rest of the frame.
    • Once you pry all of the snaps up lift the face plate off.
Conclusión
3 personas más completaron esta guía.
Un comentario
I recently replaced my front face plate on my Envy M6, which originally had one in a natural silver finish. I can confirm that the onyx black one works equally well. To think it was a Lithuanian part too. I completed the guide, but mistakenly forgot to reconnect the touchpad ribbon. But that’s my fault.
Eric Shields - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 7
Todo El Tiempo: 2,216
