Introducción
We will be showing you how to replace your screen if it is broken or damaged. This is a fairly long process which requires you to be careful.
Qué necesitas
Using a Phillips #1, remove the 8 10.6mm screws.
Also using a Phillips #1, remove the 8.6mm screw.
Using a Phillips #00, remove the four 2.3 mm black screws.
Lift the screen and frame out of the computer body.
5 personas más completaron esta guía.
