Introducción
Has your battery seemingly died far earlier than expected in your HP Envy 15 x360 laptop? This guide will show you how to fix a common cause of a dead battery.
Qué necesitas
Plug in your computer to charge and take a look at the light coming from near the charging port.
Once the battery is safely removed, plug the charging cord into the charging port on the side and plug the other end into the wall.
If the light is on after plugging it in, you have just confirmed that something is wrong with the battery, which means you're on the right track!
Unplug the charging cable.
20 personas más completaron esta guía.
9 comentarios
can you tell me the name of the battery ?
Worked like a gem. Now my battery is even charging. There must be a loose connection between the battery and mother board. Double thumbs up to you!
This worked like a charm for me. Thank you for posting!! followed directions exactly, so easy to follow. The only trouble I had was getting the keyboard detached. It was really stuck on there, but I eventually got it. Battery is charging as we speak.
