Saltar al contenido principal
HP Envy 5660 LCD Replacement
Qué necesitas
  1. HP Envy 5660 LCD Replacement, LCD: paso 1, imagen 1 de 1
    • Lift the scanner to open up the printer cartridge access area.
  2. HP Envy 5660 LCD Replacement: paso 2, imagen 1 de 2 HP Envy 5660 LCD Replacement: paso 2, imagen 2 de 2
    • Remove the two 12 mm screws with a T10 bit.
  3. HP Envy 5660 LCD Replacement: paso 3, imagen 1 de 3 HP Envy 5660 LCD Replacement: paso 3, imagen 2 de 3 HP Envy 5660 LCD Replacement: paso 3, imagen 3 de 3
    • Use a metal spudger to pry open the front panel.
    • Work your way all the way around the front panel doing the same.
    • Gently flip the cover over, exposing the motherboard.
    • There will be loud popping sounds when the cover is being separated from the rest of the printer.
  4. HP Envy 5660 LCD Replacement: paso 4, imagen 1 de 2 HP Envy 5660 LCD Replacement: paso 4, imagen 2 de 2
    • Remove the four 4.5 mm screws from the motherboard with a T6 bit.
    • Gently remove the motherboard from the top of the LCD, but make sure the ribbon cables are still attached.
    • Beware damaging the white ribbon cable.
  5. HP Envy 5660 LCD Replacement: paso 5, imagen 1 de 2 HP Envy 5660 LCD Replacement: paso 5, imagen 2 de 2
    • Remove the four 5 mm screws with a T6 bit, allowing you to separate the LCD from the cover,
  6. HP Envy 5660 LCD Replacement: paso 6, imagen 1 de 1
    • Place the metal spudger underneath the LCD and gently lift up to remove the LCD.
Conclusión
Una persona más ha completado esta guía.
Ryan Steakley
Miembro Desde 01/23/18
781 Reputación
5 Guías creadas
Equipo
Cal Poly, Team S1-G6, Livingston Winter 2018 Miembro de Cal Poly, Team S1-G6, Livingston Winter 2018
CPSU-LIVINGSTON-W18S1G6
4 Miembros
10 Guías creadas
2 comentarios
Great description but there is a part needed - the LCD. Is that part available? How do I get it?
Thanks,
PJE
pateckelberry - Contestar
Ditto, I'm in the same position, did you ever find the part/LCD replacement screen?
Tessa Robles - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 14
Todo El Tiempo: 1,110
