Saltar al contenido principal
HP Envy 4-1105dx Hard Drive Replacement
Qué necesitas
  1. HP Envy 4-1105dx  Hard Drive Replacement, Battery: paso 1, imagen 1 de 1
    • Power off the device before beginning disassembly. Disconnect all external devices.
    • Flip the device on its back.
  2. HP Envy 4-1105dx  Hard Drive Replacement: paso 2, imagen 1 de 1
    • Unscrew and remove the one 7.5 mm Phillips-head screw using Phillips #1 screwdriver.
  3. HP Envy 4-1105dx  Hard Drive Replacement: paso 3, imagen 1 de 1
    • Unscrew twelve 6.0 mm Phillips-head screws using Phillips #1 screwdriver.
  4. HP Envy 4-1105dx  Hard Drive Replacement: paso 4, imagen 1 de 1
    • Use the plastic opening tool (which is short and has a thin end for prying open device parts) to pry open the back case of the device.
  5. HP Envy 4-1105dx  Hard Drive Replacement: paso 5, imagen 1 de 1
    • Once the device is open, move the ribbon cable to the side.
  6. HP Envy 4-1105dx  Hard Drive Replacement: paso 6, imagen 1 de 1
    • Use the flat end of a plastic spudger to disconnect the battery cable from its socket in the motherboard.
  7. HP Envy 4-1105dx  Hard Drive Replacement: paso 7, imagen 1 de 1
    • Unscrew and remove the three 4.0 mm Phillips-head screws that hold the battery in place, using a Phillips #1 screwdriver.
  8. HP Envy 4-1105dx  Hard Drive Replacement: paso 8, imagen 1 de 1
    • Lift the battery up and remove.
    • Removing the battery can dislodge the touchpad bracket. Place the battery carefully over the alignment pins.
  9. HP Envy 4-1105dx  Hard Drive Replacement, Hard Drive: paso 9, imagen 1 de 2 HP Envy 4-1105dx  Hard Drive Replacement, Hard Drive: paso 9, imagen 2 de 2
    • Remove the four 4.0 mm screws that hold down the hard drive case using a Philips #1 Screwdriver.
    • Move the hard drive case and hard drive so that you can easily reach the hard drive cable.
  10. HP Envy 4-1105dx  Hard Drive Replacement: paso 10, imagen 1 de 3 HP Envy 4-1105dx  Hard Drive Replacement: paso 10, imagen 2 de 3 HP Envy 4-1105dx  Hard Drive Replacement: paso 10, imagen 3 de 3
    • Use the plastic spudger tool to loosen the hard drive SATA cable connection by pushing it away from the motherboard.
    • Once it is loose, pull the hard drive out of the socket.
    • Remove the hard drive from the device.
  11. HP Envy 4-1105dx  Hard Drive Replacement: paso 11, imagen 1 de 3 HP Envy 4-1105dx  Hard Drive Replacement: paso 11, imagen 2 de 3 HP Envy 4-1105dx  Hard Drive Replacement: paso 11, imagen 3 de 3
    • Pull out the hard drive cable from the hard drive, and set it aside.
    • Remove the four 3.0 mm screws that attach the hard drive case to the hard drive using a Philips #1 Screwdriver. If the screwdriver is too big, try #0 sized screwdriver.
  12. HP Envy 4-1105dx  Hard Drive Replacement: paso 12, imagen 1 de 1
    • Remove the hard drive from the hard drive case.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 5
Todo El Tiempo: 918
