Saltar al contenido principal
HP Envy 4-1030us Battery Replacement
Qué necesitas
  1. HP Envy 4-1030us Battery Replacement, Bottom Cover: paso 1, imagen 1 de 2 HP Envy 4-1030us Battery Replacement, Bottom Cover: paso 1, imagen 2 de 2
    • Using the Philips #0 screwdriver, remove the 12 7.5mm screws from the bottom cover.
  2. HP Envy 4-1030us Battery Replacement: paso 2, imagen 1 de 2 HP Envy 4-1030us Battery Replacement: paso 2, imagen 2 de 2
    • Using the plastic opening tool, carefully work the tool between the bottom cover and bottom chassis to loosen the connection.
    • Lift the bottom cover off of the system.
  3. HP Envy 4-1030us Battery Replacement, Battery: paso 3, imagen 1 de 2 HP Envy 4-1030us Battery Replacement, Battery: paso 3, imagen 2 de 2
    • Disconnect the battery cable from the motherboard. This will be found above the battery and below the CPU fan.
    • To take the cable out, carefully grab the head of the cable and slowly pull it outwards.
  4. HP Envy 4-1030us Battery Replacement: paso 4, imagen 1 de 2 HP Envy 4-1030us Battery Replacement: paso 4, imagen 2 de 2
    • Use the Philips #0 screwdriver to remove the three 4.2mm screws that are securing the battery to the board.
  5. HP Envy 4-1030us Battery Replacement: paso 5, imagen 1 de 2 HP Envy 4-1030us Battery Replacement: paso 5, imagen 2 de 2
    • Then slowly remove the battery from the right side of the battery and then raise it up.
    • Make sure to move the USB Audio board cable away from the battery incase it gets caught.
Conclusión
2 personas más completaron esta guía.
Equipo
USF Tampa, Team S1-G1, Thompson Fall 2017 Miembro de USF Tampa, Team S1-G1, Thompson Fall 2017
USFT-THOMPSON-F17S1G1
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 6
Todo El Tiempo: 995
