Saltar al contenido principal
HP Envy 17m-ae111dx Battery Replacement
Qué necesitas
  1. HP Envy 17m-ae111dx Battery Replacement, Back Cover: paso 1, imagen 1 de 1
    • Power off your laptop before beginning disassembly.
    • Place the laptop on its back.
  2. HP Envy 17m-ae111dx Battery Replacement: paso 2, imagen 1 de 3 HP Envy 17m-ae111dx Battery Replacement: paso 2, imagen 2 de 3 HP Envy 17m-ae111dx Battery Replacement: paso 2, imagen 3 de 3
    • Remove the plastic covering to the Disk Reader.
    • Locate the small hole on the side of the disk reader. Insert the T5 Torx head screwdriver (or device of similar thickness) to release the covering for the disk reader.
    • If the button on the side is jammed, pry off the covering by using the iFixit Opening Tool.
  3. HP Envy 17m-ae111dx Battery Replacement: paso 3, imagen 1 de 3 HP Envy 17m-ae111dx Battery Replacement: paso 3, imagen 2 de 3 HP Envy 17m-ae111dx Battery Replacement: paso 3, imagen 3 de 3
    • Unscrew all visible screws.
    • Use the T5 Torx Screwdriver and remove the four visible 6.5mm screws on the bottom of the laptop.
    • One 2.5mm screw, is located where the disk reader was once located. Use a Phillips #00 screwdriver to remove the single screw that connects the bottom cover of the laptop to the bottom frame.
  4. HP Envy 17m-ae111dx Battery Replacement: paso 4, imagen 1 de 2 HP Envy 17m-ae111dx Battery Replacement: paso 4, imagen 2 de 2
    • Pry the gripper completely off to expose the two screws.
    • Remove the 2.5mm screws under the gripper nearest to the hinge using the Phillips #00 screwdriver.
  5. HP Envy 17m-ae111dx Battery Replacement: paso 5, imagen 1 de 3 HP Envy 17m-ae111dx Battery Replacement: paso 5, imagen 2 de 3 HP Envy 17m-ae111dx Battery Replacement: paso 5, imagen 3 de 3
    • Use the iFixit opening tool to pry off the back cover.
    • Ensure that you go all the way around the laptop with the tool to take it off.
  6. HP Envy 17m-ae111dx Battery Replacement, Battery: paso 6, imagen 1 de 1
    • Use a Phillips #00 screwdriver to remove all seven screws.
  7. HP Envy 17m-ae111dx Battery Replacement: paso 7, imagen 1 de 3 HP Envy 17m-ae111dx Battery Replacement: paso 7, imagen 2 de 3 HP Envy 17m-ae111dx Battery Replacement: paso 7, imagen 3 de 3
    • Unplug the battery from the connection port and remove the battery from the device.
Conclusión
3 personas más completaron esta guía.
Un comentario
These instructions were also applicable to an HP 17ar050 Pavillion Laptop.
George Willis - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 38
Todo El Tiempo: 3,861
