Saltar al contenido principal
HP Envy 17-J013CL Memory Module Replacement
Qué necesitas
  1. HP Envy 17-J013CL Memory Module Replacement, Battery: paso 1, imagen 1 de 1
    • Lay the laptop with the battery facing towards you.
    • Remember to disconnect the AC cable and other power sources from the device before replacing/repairing parts.
  2. HP Envy 17-J013CL Memory Module Replacement: paso 2, imagen 1 de 1
    • Grab hold of the small battery slider and apply pressure to the right.
    • The laptop itself will push the battery out for you once the switch slides all the way to the right.
  3. HP Envy 17-J013CL Memory Module Replacement: paso 3, imagen 1 de 3 HP Envy 17-J013CL Memory Module Replacement: paso 3, imagen 2 de 3 HP Envy 17-J013CL Memory Module Replacement: paso 3, imagen 3 de 3
    • Pull the battery out and let go of the battery slider.
  4. HP Envy 17-J013CL Memory Module Replacement, Back Panel: paso 4, imagen 1 de 2 HP Envy 17-J013CL Memory Module Replacement, Back Panel: paso 4, imagen 2 de 2
    • Use a PH1-screwdriver to loosen the 7mm screw. The screw will not fully come out as it is held by a washer underneath but will come out enough to open it.
  5. HP Envy 17-J013CL Memory Module Replacement: paso 5, imagen 1 de 1
    • Gently pull the back panel off starting from the battery side towards the back.
    • Pull it back as it snaps out of the holding sockets.
    • It is preferred to use both hands when pulling the back panel off to prevent bending it out of shape.
  6. HP Envy 17-J013CL Memory Module Replacement, Memory Module: paso 6, imagen 1 de 2 HP Envy 17-J013CL Memory Module Replacement, Memory Module: paso 6, imagen 2 de 2
    • Locate the memory stick inside.
  7. HP Envy 17-J013CL Memory Module Replacement: paso 7, imagen 1 de 2 HP Envy 17-J013CL Memory Module Replacement: paso 7, imagen 2 de 2
    • On both sides of the module, place a thumb on each of the metallic holding pins.
    • Gently pull on the pins to release the spring holding in the module.
  8. HP Envy 17-J013CL Memory Module Replacement: paso 8, imagen 1 de 2 HP Envy 17-J013CL Memory Module Replacement: paso 8, imagen 2 de 2
    • Gently slide the module out of the memory slot.
    • Pay in mind of the module's orientation as it will only go in one way with a little gap in the module to identify orientation.
Conclusión
Matt McBride
Miembro Desde 02/02/17
845 Reputación
6 Guías creadas
Equipo
USF Tampa, Team 16-6, Blackwell Spring 2017 Miembro de USF Tampa, Team 16-6, Blackwell Spring 2017
USFT-BLACKWELL-S17S16G6
3 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 9
Todo El Tiempo: 666
