Introducción
The back panel on the HP Envy 17 is a simple plate that covers the underside of the laptop. Once removed it gives easier access to laptop components such as the WLAN module and RAM module. This is a crucial step in order to delve deeper into the device.
Qué necesitas
Use a PH1-screwdriver to loosen the 7mm screw. The screw will not fully come out as it is held by a washer underneath but will come out enough to open it.
To reassemble your device, place the back panel from opposite the battery end in the slots and place down until it snaps into place.
