Saltar al contenido principal
HP Envy 17-3070NR Wireless Card Replacement
Qué necesitas
  1. HP Envy 17-3070NR Wireless Card Replacement, Back Cover: paso 1, imagen 1 de 2 HP Envy 17-3070NR Wireless Card Replacement, Back Cover: paso 1, imagen 2 de 2
    • Before you begin taking apart the computer, make sure that it is completely powered off.
    • Slide the release latch away from the nearest edge.
    • Slide the back cover off of the computer.
  2. HP Envy 17-3070NR Wireless Card Replacement: paso 2, imagen 1 de 3 HP Envy 17-3070NR Wireless Card Replacement: paso 2, imagen 2 de 3 HP Envy 17-3070NR Wireless Card Replacement: paso 2, imagen 3 de 3
    • Remove the six 3.7mm Phillips screws.
    • Slide the back cover until it clicks, then lift it straight off.
  3. HP Envy 17-3070NR Wireless Card Replacement, Wireless Card: paso 3, imagen 1 de 3 HP Envy 17-3070NR Wireless Card Replacement, Wireless Card: paso 3, imagen 2 de 3 HP Envy 17-3070NR Wireless Card Replacement, Wireless Card: paso 3, imagen 3 de 3
    • Unscrew 4.5mm Phillips screw.
    • Unplug both antenna connectors by carefully pulling them upwards.
    • During re-assembly make sure to match numbers(1 or 2) on the antenna cable and the wireless card.
  4. HP Envy 17-3070NR Wireless Card Replacement: paso 4, imagen 1 de 3 HP Envy 17-3070NR Wireless Card Replacement: paso 4, imagen 2 de 3 HP Envy 17-3070NR Wireless Card Replacement: paso 4, imagen 3 de 3
    • Pull wireless card up and away from you.
Conclusión
Jasper Lewin
Miembro Desde 04/21/15
750 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 14-8, Amido Spring 2015 Miembro de Cal Poly, Team 14-8, Amido Spring 2015
CPSU-AMIDO-S15S14G8
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 14
Todo El Tiempo: 1,075
