Saltar al contenido principal
HP Envy 17-3070NR Top Cover Replacement
Qué necesitas
  1. HP Envy 17-3070NR Top Cover Replacement, Back Cover: paso 1, imagen 1 de 2 HP Envy 17-3070NR Top Cover Replacement, Back Cover: paso 1, imagen 2 de 2
    • Before you begin taking apart the computer, make sure that it is completely powered off.
    • Slide the release latch away from the nearest edge.
    • Slide the back cover off of the computer.
  2. HP Envy 17-3070NR Top Cover Replacement: paso 2, imagen 1 de 3 HP Envy 17-3070NR Top Cover Replacement: paso 2, imagen 2 de 3 HP Envy 17-3070NR Top Cover Replacement: paso 2, imagen 3 de 3
    • Remove the six 3.7mm Phillips screws.
    • Slide the back cover until it clicks, then lift it straight off.
  3. HP Envy 17-3070NR Top Cover Replacement, Hard Drive: paso 3, imagen 1 de 3 HP Envy 17-3070NR Top Cover Replacement, Hard Drive: paso 3, imagen 2 de 3 HP Envy 17-3070NR Top Cover Replacement, Hard Drive: paso 3, imagen 3 de 3
    • Remove the four 3.7mm Phillips screws that hold the hard drive onto the computer.
    • Remove the hard drive by lifting it out of its cavity.
    • Unplug the hard drive cable that connects it to the main assembly.
  4. HP Envy 17-3070NR Top Cover Replacement, Optical Drive: paso 4, imagen 1 de 3 HP Envy 17-3070NR Top Cover Replacement, Optical Drive: paso 4, imagen 2 de 3 HP Envy 17-3070NR Top Cover Replacement, Optical Drive: paso 4, imagen 3 de 3
    • Remove the four 3.7mm Phillips screws that secure the optical drive to the computer.
    • Slowly lift the optical drive away from the computer ensuring that you don't put stress on the connecting cable.
    • Do not fully lift off the optical drive as there is still a cable that connects it to the motherboard.
    • Remove Sub Speaker assembly first in order to remove Optical drive. Carefully disconnect speaker connector.
  5. HP Envy 17-3070NR Top Cover Replacement: paso 6, imagen 1 de 3 HP Envy 17-3070NR Top Cover Replacement: paso 6, imagen 2 de 3 HP Envy 17-3070NR Top Cover Replacement: paso 6, imagen 3 de 3
    • Carefully disconnect the connecting cable by lifting the white clamp with a Flathead screwdriver and pulling on the blue tab away from connector.
  6. HP Envy 17-3070NR Top Cover Replacement, Battery: paso 7, imagen 1 de 2 HP Envy 17-3070NR Top Cover Replacement, Battery: paso 7, imagen 2 de 2
    • Disconnect the multi-colored battery cable from the main assembly by gently pulling upward on it.
  7. HP Envy 17-3070NR Top Cover Replacement: paso 8, imagen 1 de 3 HP Envy 17-3070NR Top Cover Replacement: paso 8, imagen 2 de 3 HP Envy 17-3070NR Top Cover Replacement: paso 8, imagen 3 de 3
    • Remove the two 3.8 mm Torx screws using M8 Torx screwdriver.
    • Remove the battery by pulling it straight out away from the computer.
    • It is much easier to use the battery cable to carefully lift the battery off than to try to pry it off with tools.
  8. HP Envy 17-3070NR Top Cover Replacement, Subwoofer: paso 9, imagen 1 de 3 HP Envy 17-3070NR Top Cover Replacement, Subwoofer: paso 9, imagen 2 de 3 HP Envy 17-3070NR Top Cover Replacement, Subwoofer: paso 9, imagen 3 de 3
    • Unscrew the three 6.5mm Phillips shoulder screws that connect the subwoofer to the computer.
    • Disconnect the red and black subwoofer cable from the system board by pulling it upwards.
    • Remove the subwoofer by pulling straight up from the main assembly.
  9. HP Envy 17-3070NR Top Cover Replacement, Top Cover: paso 10, imagen 1 de 3 HP Envy 17-3070NR Top Cover Replacement, Top Cover: paso 10, imagen 2 de 3 HP Envy 17-3070NR Top Cover Replacement, Top Cover: paso 10, imagen 3 de 3
    • Remove the first connector by lifting the white clamp with a Flathead screwdriver and pulling the connector to your right.
  10. HP Envy 17-3070NR Top Cover Replacement: paso 11, imagen 1 de 3 HP Envy 17-3070NR Top Cover Replacement: paso 11, imagen 2 de 3 HP Envy 17-3070NR Top Cover Replacement: paso 11, imagen 3 de 3
    • Remove the second connector by gently pulling upward.
  11. HP Envy 17-3070NR Top Cover Replacement: paso 12, imagen 1 de 1
    • Remove the seventeen 6.6mm Phillips screws.
    • Remove the three 3.6 mm Phillips screws.
    • Remove the eleven 3.2mm Phillips screws
    • Three of the 3.2mm Phillips screws are located underneath the black hard drive flap.
    • Make sure that you keep the screws organized so that you keep track of all of the different sizes and locations.
  12. HP Envy 17-3070NR Top Cover Replacement: paso 13, imagen 1 de 3 HP Envy 17-3070NR Top Cover Replacement: paso 13, imagen 2 de 3 HP Envy 17-3070NR Top Cover Replacement: paso 13, imagen 3 de 3
    • Flip the laptop over.
    • Use a Plastic Opening tool to carefully pry all around the top cover up off of the remaining assembly.
    • Starting location for prying does not matter as long as you pry all around the frame before lifting it off.
    • Do not fully lift the top cover because there are cables that will need to be disconnected before removal.
  13. HP Envy 17-3070NR Top Cover Replacement: paso 14, imagen 1 de 2 HP Envy 17-3070NR Top Cover Replacement: paso 14, imagen 2 de 2
    • Gently pull the white connector shown in the picture towards you to disconnect it from the system board.
  14. HP Envy 17-3070NR Top Cover Replacement: paso 15, imagen 1 de 1
    • Gently pull the black connector towards you to disconnect the top cover from the main assembly.
    • Once both connectors are disconnected, lift the top cover off of the main assembly.
Conclusión
Jasper Lewin
Miembro Desde 04/21/15
750 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 14-8, Amido Spring 2015 Miembro de Cal Poly, Team 14-8, Amido Spring 2015
CPSU-AMIDO-S15S14G8
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 5
Todo El Tiempo: 1,676
