Saltar al contenido principal
HP Envy 17-3070NR Optical Drive Replacement
Qué necesitas
  1. HP Envy 17-3070NR Optical Drive Replacement, Back Cover: paso 1, imagen 1 de 2 HP Envy 17-3070NR Optical Drive Replacement, Back Cover: paso 1, imagen 2 de 2
    • Before you begin taking apart the computer, make sure that it is completely powered off.
    • Slide the release latch away from the nearest edge.
    • Slide the back cover off of the computer.
  2. HP Envy 17-3070NR Optical Drive Replacement: paso 2, imagen 1 de 3 HP Envy 17-3070NR Optical Drive Replacement: paso 2, imagen 2 de 3 HP Envy 17-3070NR Optical Drive Replacement: paso 2, imagen 3 de 3
    • Remove the six 3.7mm Phillips screws.
    • Slide the back cover until it clicks, then lift it straight off.
  3. HP Envy 17-3070NR Optical Drive Replacement, Optical Drive: paso 3, imagen 1 de 3 HP Envy 17-3070NR Optical Drive Replacement, Optical Drive: paso 3, imagen 2 de 3 HP Envy 17-3070NR Optical Drive Replacement, Optical Drive: paso 3, imagen 3 de 3
    • Remove the four 3.7mm Phillips screws that secure the optical drive to the computer.
    • Slowly lift the optical drive away from the computer ensuring that you don't put stress on the connecting cable.
    • Do not fully lift off the optical drive as there is still a cable that connects it to the motherboard.
    • Remove Sub Speaker assembly first in order to remove Optical drive. Carefully disconnect speaker connector.
  4. HP Envy 17-3070NR Optical Drive Replacement: paso 5, imagen 1 de 3 HP Envy 17-3070NR Optical Drive Replacement: paso 5, imagen 2 de 3 HP Envy 17-3070NR Optical Drive Replacement: paso 5, imagen 3 de 3
    • Carefully disconnect the connecting cable by lifting the white clamp with a Flathead screwdriver and pulling on the blue tab away from connector.
Conclusión
Jon Fuson
Miembro Desde 04/21/15
140 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 14-8, Amido Spring 2015 Miembro de Cal Poly, Team 14-8, Amido Spring 2015
CPSU-AMIDO-S15S14G8
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 7
Todo El Tiempo: 1,221
