Saltar al contenido principal
HP Envy 17-3070NR Battery Replacement
Qué necesitas
  1. HP Envy 17-3070NR Battery Replacement, Back Cover: paso 1, imagen 1 de 2 HP Envy 17-3070NR Battery Replacement, Back Cover: paso 1, imagen 2 de 2
    • Before you begin taking apart the computer, make sure that it is completely powered off.
    • Slide the release latch away from the nearest edge.
    • Slide the back cover off of the computer.
  2. HP Envy 17-3070NR Battery Replacement: paso 2, imagen 1 de 3 HP Envy 17-3070NR Battery Replacement: paso 2, imagen 2 de 3 HP Envy 17-3070NR Battery Replacement: paso 2, imagen 3 de 3
    • Remove the six 3.7mm Phillips screws.
    • Slide the back cover until it clicks, then lift it straight off.
  3. HP Envy 17-3070NR Battery Replacement, Battery: paso 3, imagen 1 de 2 HP Envy 17-3070NR Battery Replacement, Battery: paso 3, imagen 2 de 2
    • Disconnect the multi-colored battery cable from the main assembly by gently pulling upward on it.
  4. HP Envy 17-3070NR Battery Replacement: paso 4, imagen 1 de 3 HP Envy 17-3070NR Battery Replacement: paso 4, imagen 2 de 3 HP Envy 17-3070NR Battery Replacement: paso 4, imagen 3 de 3
    • Remove the two 3.8 mm Torx screws using M8 Torx screwdriver.
    • Remove the battery by pulling it straight out away from the computer.
    • It is much easier to use the battery cable to carefully lift the battery off than to try to pry it off with tools.
Conclusión
5 personas más completaron esta guía.
Abby Lentz
Miembro Desde 04/21/15
586 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 14-8, Amido Spring 2015 Miembro de Cal Poly, Team 14-8, Amido Spring 2015
CPSU-AMIDO-S15S14G8
Miembros de 4
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 6
Todo El Tiempo: 8,865
