Saltar al contenido principal
HP Envy 15-u001dx Battery Replacement
Guía Archivada
Esta guía se mantiene únicamente para fines históricos. Utiliza la última versión de la guía para llevar a cabo tu reparación.
Qué necesitas
  1. HP Envy 15-u001dx Battery Replacement, HP Envy 15-u001dx Disassembly: paso 1, imagen 1 de 1
    • Remove the two no-slip covers on the rear, bottom side using spudger shown in top center of picture.
    • The two in the front do not have to be removed as there are no screws underneath them.
  2. HP Envy 15-u001dx Battery Replacement: paso 2, imagen 1 de 1
    • Remove the two cover tabs towards center of the bottom as there are screws underneath them.
  3. HP Envy 15-u001dx Battery Replacement: paso 3, imagen 1 de 1
    • Remove all fourteen 4.5 mm screws from the bottom using a Phillips #0 screwdriver. Each location is marked by a red circle in the picture.
  4. HP Envy 15-u001dx Battery Replacement: paso 4, imagen 1 de 1
    • Separate the top cover by using a spudger to go around the sides freeing the inside latches.
    • Once the bottom is free, carefully open to the inside as there are two ribbons that connect your keyboard and touch pad to the top cover.
  5. HP Envy 15-u001dx Battery Replacement: paso 5, imagen 1 de 2 HP Envy 15-u001dx Battery Replacement: paso 5, imagen 2 de 2
    • Use the spudger to detach the two ribbons from their connectors.
    • The regular black nylon spudger should be used whenever possible, especially around sensitive internal components.
  6. HP Envy 15-u001dx Battery Replacement, Battery: paso 6, imagen 1 de 3 HP Envy 15-u001dx Battery Replacement, Battery: paso 6, imagen 2 de 3 HP Envy 15-u001dx Battery Replacement, Battery: paso 6, imagen 3 de 3
    • Remove the three 3 mm screws from the battery using Phillips #0 screwdriver.
  7. HP Envy 15-u001dx Battery Replacement: paso 7, imagen 1 de 1
    • Use a spudger to gently detach the battery connector.
Conclusión
3 personas más completaron esta guía.
Dakota Presley
Miembro Desde 10/05/16
885 Reputación
6 Guías creadas
Equipo
USF Tampa, Team 9-4, Lacy Fall 2016 Miembro de USF Tampa, Team 9-4, Lacy Fall 2016
USFT-LACY-F16S9G4
Miembros de 4
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 1,046
