Saltar al contenido principal
HP Elitebook x360 1040 G5 Screen display Replacement
Qué necesitas
  1. HP Elitebook x360 1040 G5 Screen display Replacement, Screen display: paso 1, imagen 1 de 3 HP Elitebook x360 1040 G5 Screen display Replacement, Screen display: paso 1, imagen 2 de 3 HP Elitebook x360 1040 G5 Screen display Replacement, Screen display: paso 1, imagen 3 de 3
    • Open your laptop.
    • Apply heat to the perimeter of screen display using the low setting on the heat gun or hair dryer. Keep the heat gun at least 6 inches away from the device at all time to prevent damage to other components.
    • Continue to apply heat for 5 to 10 minutes.
  2. HP Elitebook x360 1040 G5 Screen display Replacement: paso 2, imagen 1 de 3 HP Elitebook x360 1040 G5 Screen display Replacement: paso 2, imagen 2 de 3 HP Elitebook x360 1040 G5 Screen display Replacement: paso 2, imagen 3 de 3
    • Using the jimmy tool pry outward on the screen display, starting near one of the top corners.
    • Carefully pry along the perimeter of the display until the screen can be easily removed.
    • Lay the screen face down on the keyboard for the next step.
  3. HP Elitebook x360 1040 G5 Screen display Replacement: paso 3, imagen 1 de 2 HP Elitebook x360 1040 G5 Screen display Replacement: paso 3, imagen 2 de 2
    • Carefully remove the clear adhesive protector from the smallest ribbon cable, located closest to the laptop hinge.
    • Gently slide the connector out of the harness, moving it towards the side of the laptop with the power button.
  4. HP Elitebook x360 1040 G5 Screen display Replacement: paso 4, imagen 1 de 3 HP Elitebook x360 1040 G5 Screen display Replacement: paso 4, imagen 2 de 3 HP Elitebook x360 1040 G5 Screen display Replacement: paso 4, imagen 3 de 3
    • Carefully remove the clear adhesive protector from the last ribbon cable, located on the large black strip on the back of the screen display.
    • Gently remove the ribbon cable from the harness by moving it toward the laptop hinge.
  5. HP Elitebook x360 1040 G5 Screen display Replacement: paso 5, imagen 1 de 3 HP Elitebook x360 1040 G5 Screen display Replacement: paso 5, imagen 2 de 3 HP Elitebook x360 1040 G5 Screen display Replacement: paso 5, imagen 3 de 3
    • Remove the screen from the laptop.
Conclusión
Una persona más ha completado esta guía.
Tyler A Cobb
Miembro Desde 09/03/19
321 Reputación
2 Guías creadas
Equipo
IUPUI, Team S1-G1, Hovde Fall 2019 Miembro de IUPUI, Team S1-G1, Hovde Fall 2019
IUPUI-HOVDE-F19S1G1
3 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 15
Ultimos 30 días: 44
Todo El Tiempo: 1,857
