Saltar al contenido principal
HP Elitebook x360 1040 G5 Motherboard Replacement
Qué necesitas
  1. HP Elitebook x360 1040 G5 Motherboard Replacement, Lower Case: paso 1, imagen 1 de 2 HP Elitebook x360 1040 G5 Motherboard Replacement, Lower Case: paso 1, imagen 2 de 2
    • Power off device before disassembly.
    • Use the T5 Torx screwdriver to remove the six 4 mm screws from the underside of the laptop.
  2. HP Elitebook x360 1040 G5 Motherboard Replacement: paso 2, imagen 1 de 2 HP Elitebook x360 1040 G5 Motherboard Replacement: paso 2, imagen 2 de 2
    • Pry open the lower case from where it meets the laptop base.
    • Remove the lower case from the work area.
  3. HP Elitebook x360 1040 G5 Motherboard Replacement, Battery: paso 3, imagen 1 de 2 HP Elitebook x360 1040 G5 Motherboard Replacement, Battery: paso 3, imagen 2 de 2
    • Use the Phillips 1 screwdriver to remove the five 3mm Phillips screws from the battery assembly.
  4. HP Elitebook x360 1040 G5 Motherboard Replacement: paso 4, imagen 1 de 3 HP Elitebook x360 1040 G5 Motherboard Replacement: paso 4, imagen 2 de 3 HP Elitebook x360 1040 G5 Motherboard Replacement: paso 4, imagen 3 de 3
    • Carefully remove the power supply connector by pulling on both sides of its head.
    • Do not tug on the wires as they may become damaged.
    • Lift the battery from its position, removing it from the device.
  5. HP Elitebook x360 1040 G5 Motherboard Replacement, Motherboard: paso 5, imagen 1 de 2 HP Elitebook x360 1040 G5 Motherboard Replacement, Motherboard: paso 5, imagen 2 de 2
    • With the battery removed, begin by removing the two coaxial connectors located near the hinge using an ESD-safe spudger.
    • To do this, slide the tip of the spudger under the wire until it is snug against the connector. Then, pry straight up from the board.
  6. HP Elitebook x360 1040 G5 Motherboard Replacement: paso 6, imagen 1 de 3 HP Elitebook x360 1040 G5 Motherboard Replacement: paso 6, imagen 2 de 3 HP Elitebook x360 1040 G5 Motherboard Replacement: paso 6, imagen 3 de 3
    • Remove the three white and two brown ribbon cables located on the bottom of the motherboard.
    • Use a spudger to carefully push on each side of the connector in order to release the cable.
  7. HP Elitebook x360 1040 G5 Motherboard Replacement: paso 7, imagen 1 de 2 HP Elitebook x360 1040 G5 Motherboard Replacement: paso 7, imagen 2 de 2
    • Remove sliding connector located near the bottom right corner of the motherboard.
    • Gently push on each side of the connector using a spudger until it is free.
  8. HP Elitebook x360 1040 G5 Motherboard Replacement: paso 8, imagen 1 de 2 HP Elitebook x360 1040 G5 Motherboard Replacement: paso 8, imagen 2 de 2
    • Remove the foil protector from the right side of the motherboard by gently peeling it back with the opening tool.
    • Remove the ribbon connector underneath using the spudger.
  9. HP Elitebook x360 1040 G5 Motherboard Replacement: paso 9, imagen 1 de 3 HP Elitebook x360 1040 G5 Motherboard Replacement: paso 9, imagen 2 de 3 HP Elitebook x360 1040 G5 Motherboard Replacement: paso 9, imagen 3 de 3
    • Remove the two flat connectors located on both sides of the motherboard near the fans.
    • Gently pry the connector straight up from the motherboard using a spudger or opening tool.
  10. HP Elitebook x360 1040 G5 Motherboard Replacement: paso 10, imagen 1 de 2 HP Elitebook x360 1040 G5 Motherboard Replacement: paso 10, imagen 2 de 2
    • Remove the five M2 X 3mm screws from the perimeter of the motherboard using the Phillips #1 screwdriver.
    • Remove the two M2 X 5mm screws from the upper corners of the motherboard using the Phillips #1 screwdriver.
    • Finally, remove the two interior M2 X 3mm screws from the motherboard's cooling system.
  11. HP Elitebook x360 1040 G5 Motherboard Replacement: paso 11, imagen 1 de 1
    • Lift the motherboard carefully from the computer shell. The motherboard can now be replaced.
Conclusión
Una persona más ha completado esta guía.
Tyler A Cobb
Miembro Desde 09/03/19
321 Reputación
2 Guías creadas
Equipo
IUPUI, Team S1-G1, Hovde Fall 2019 Miembro de IUPUI, Team S1-G1, Hovde Fall 2019
IUPUI-HOVDE-F19S1G1
3 Miembros
4 Guías creadas
Un comentario
Hi! I think you should also mention that there is a sim-card slot dummy holding a motherbord, you can not lift it when a holder or a dummy is inside. it should be poked out with a pincer through the hole one the side of a motherboard above the slot itself (it do not eject on a spring like a normal sim card holder)
Сергей Соколов - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 38
Todo El Tiempo: 1,601
