Introducción
Use this guide if you are experiencing issues with your laptop’s fan. These include your device overheating, fans making noise and throttling, or your laptop’s performance dropping. This guide includes instructions to remove and replace your laptop’s fan. Note that removing the fan requires the application of new thermal paste.
Qué necesitas
Use the T5 Torx screwdriver to remove the six 4 mm screws from the underside of the laptop.
Use the Phillips 0 screwdriver to remove the six 3mm Phillips screws from the fan assembly.
- To reassemble your device, follow these instructions in reverse order.
Una persona más ha completado esta guía.
