Saltar al contenido principal
HP Elitebook Folio 9470m Keyboard Replacement
Qué necesitas
  1. HP Elitebook Folio 9470m Keyboard Replacement, Keyboard: paso 1, imagen 1 de 3 HP Elitebook Folio 9470m Keyboard Replacement, Keyboard: paso 1, imagen 2 de 3 HP Elitebook Folio 9470m Keyboard Replacement, Keyboard: paso 1, imagen 3 de 3
    • Flip laptop over.
  2. HP Elitebook Folio 9470m Keyboard Replacement: paso 2, imagen 1 de 2 HP Elitebook Folio 9470m Keyboard Replacement: paso 2, imagen 2 de 2
    • Remove battery by pushing slide over to red, lifting slightly up while pulling the battery out.
  3. HP Elitebook Folio 9470m Keyboard Replacement: paso 3, imagen 1 de 3 HP Elitebook Folio 9470m Keyboard Replacement: paso 3, imagen 2 de 3 HP Elitebook Folio 9470m Keyboard Replacement: paso 3, imagen 3 de 3
    • Remove hard drive cover plate by unscrewing the 2 Phillips head screws and lifting slightly up and out.
  4. HP Elitebook Folio 9470m Keyboard Replacement: paso 4, imagen 1 de 3 HP Elitebook Folio 9470m Keyboard Replacement: paso 4, imagen 2 de 3 HP Elitebook Folio 9470m Keyboard Replacement: paso 4, imagen 3 de 3
    • Remove back cover by unscrewing the 3 Phillips head screws, then lift the plate up and out.
  5. HP Elitebook Folio 9470m Keyboard Replacement: paso 5, imagen 1 de 1
    • Remove the 4 Phillips head keyboard screws.
    • The screws are also marked with small keyboard icons to distinguish them.
  6. HP Elitebook Folio 9470m Keyboard Replacement: paso 6, imagen 1 de 3 HP Elitebook Folio 9470m Keyboard Replacement: paso 6, imagen 2 de 3 HP Elitebook Folio 9470m Keyboard Replacement: paso 6, imagen 3 de 3
    • Flip the laptop over and locate the 2 tabs on the left or right sides. They will be slightly visible in the space between the keyboard and frame.
    • Using a plastic opening tool, push the tabs in while pulling up to disconnect the tabs from the keyboard frame.
    • Once both tabs become unclipped, lift the keyboard up gently allowing it to slightly bend as the front and back tabs come out.
  7. HP Elitebook Folio 9470m Keyboard Replacement: paso 7, imagen 1 de 2 HP Elitebook Folio 9470m Keyboard Replacement: paso 7, imagen 2 de 2
    • While lifting the keyboard up only enough to see underneath, unclip and remove the ribbon wire to fully detach the keyboard.
Conclusión
Una persona más ha completado esta guía.
Kenneth Bowers
Miembro Desde 04/08/16
1,381 Reputación
7 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 14
Ultimos 30 días: 62
Todo El Tiempo: 5,430
