Saltar al contenido principal
HP Elitebook 8570w Optical Drive Replacement
Qué necesitas
  1. HP Elitebook 8570w Optical Drive Replacement, Optical Drive: paso 1, imagen 1 de 1
    • Begin by removing the computers back covering.
    • Use the right slider to unlock the backing.
    • Slide the backing towards you while holding the slider to remove it.
  2. HP Elitebook 8570w Optical Drive Replacement: paso 2, imagen 1 de 1
    • Once the backing is removed, locate the panel to the left where the optical drive is stored.
    • Locate the single screw in the photo.
    • Unscrew the 0.8mm Phillips screw and place to the side.
  3. HP Elitebook 8570w Optical Drive Replacement: paso 3, imagen 1 de 1
    • Locate the small metal piece in the photo.
    • Using a tool, push the piece in the given direction.
  4. HP Elitebook 8570w Optical Drive Replacement: paso 4, imagen 1 de 2 HP Elitebook 8570w Optical Drive Replacement: paso 4, imagen 2 de 2
    • Once pushing the piece outwards, the optical drive will pop out of the side of the computer.
    • Grab the optical drive and carefully remove it from the back of the computer.
Conclusión
MJ Routh
Miembro Desde 11/06/17
465 Reputación
3 Guías creadas
Equipo
Baylor, Team S8-G5, Johnson Fall 2017 Miembro de Baylor, Team S8-G5, Johnson Fall 2017
BU-JOHNSON-F17S8G5
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 13
Todo El Tiempo: 1,929
