Saltar al contenido principal
HP Elitebook 8570w Hard Drive Replacement
Qué necesitas
  1. HP Elitebook 8570w Hard Drive Replacement, Hard Drive: paso 1, imagen 1 de 1
    • To begin, you will need to remove the battery by sliding the left slider (red) to the left.
    • Push the battery away from you to release it.
    • Then, use the right slider to remove the computer's backing (shown in image)
    • Slide the backing towards you to remove it.
  2. HP Elitebook 8570w Hard Drive Replacement: paso 2, imagen 1 de 1
    • Once the backing has been removed, you will be able to locate the computer's hard drive in the bottom left corner.
  3. HP Elitebook 8570w Hard Drive Replacement: paso 3, imagen 1 de 1
    • To remove the hard drive compartment's cover, unscrew the two 0.8mm Phillips screws with a P1 Phillips-head screwdriver.
    • Open by lifting the left side of the cover so it is facing upwards and outwards.
    • The black screws, not the gold screws.
  4. HP Elitebook 8570w Hard Drive Replacement: paso 4, imagen 1 de 1
    • Use the same screwdriver to loosen all three screws at the attachment points of the silver hard drive caddy.
    • These screws do not need to be completely removed.
  5. HP Elitebook 8570w Hard Drive Replacement: paso 5, imagen 1 de 1
    • To remove the caddy and gain access to the hard drive, pull the black tab up to release it from the caddy.
    • Once you can grab the tab with your fingers, pull it to the left to disconnect the hard drive from the computer.
  6. HP Elitebook 8570w Hard Drive Replacement: paso 6, imagen 1 de 1
    • The hard drive can now be replaced inside the caddy.
Conclusión
5 personas más completaron esta guía.
MJ Routh
Miembro Desde 11/06/17
465 Reputación
3 Guías creadas
Equipo
Baylor, Team S8-G5, Johnson Fall 2017 Miembro de Baylor, Team S8-G5, Johnson Fall 2017
BU-JOHNSON-F17S8G5
3 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 10
Ultimos 30 días: 53
Todo El Tiempo: 14,425
