Saltar al contenido principal
HP Elitebook 8570w Display Replacement
Qué necesitas
  1. HP Elitebook 8570w Display Replacement, Display: paso 1, imagen 1 de 3 HP Elitebook 8570w Display Replacement, Display: paso 1, imagen 2 de 3 HP Elitebook 8570w Display Replacement, Display: paso 1, imagen 3 de 3
    • With the computer opened, locate the square buttons on both bottom corners of the display.
    • Using a tool or finger, wedge the squares off revealing a screw on each corner.
  2. HP Elitebook 8570w Display Replacement: paso 2, imagen 1 de 1
    • Use a T9 screwdriver to unscrew both 0.4mm Torx screws.
  3. HP Elitebook 8570w Display Replacement: paso 3, imagen 1 de 2 HP Elitebook 8570w Display Replacement: paso 3, imagen 2 de 2
    • Use an opening tool or spudger to peel back the outer rim of the display.
    • Continue to peel back the entire rim.
  4. HP Elitebook 8570w Display Replacement: paso 4, imagen 1 de 1
    • Unscrew ONLY the bottom 0.8mm T9 Torx screw on both sides of the display.
  5. HP Elitebook 8570w Display Replacement: paso 5, imagen 1 de 3 HP Elitebook 8570w Display Replacement: paso 5, imagen 2 de 3 HP Elitebook 8570w Display Replacement: paso 5, imagen 3 de 3
    • Now locate the two screws on each side at the bottom of the display.
    • TOP screw: unscrew partially.
    • BOTTOM screw: completely unscrew and set to the side.
    • Complete on both sides of display.
    • Carefully separate the display from the top cover.
    • Be sure to not let the top cover fall back
  6. HP Elitebook 8570w Display Replacement: paso 6, imagen 1 de 2 HP Elitebook 8570w Display Replacement: paso 6, imagen 2 de 2
    • Use a Phillips #00 screwdriver to unscrew all four 0.8 mm screws from the left side of the display frame. Repeat for the right side.
    • Push the metal plates/rods that were attached to the display towards the top cover.
    • The display should be completely free of the top cover and able to lay flat on the keyboard (refer to photo #2).
  7. HP Elitebook 8570w Display Replacement: paso 7, imagen 1 de 3 HP Elitebook 8570w Display Replacement: paso 7, imagen 2 de 3 HP Elitebook 8570w Display Replacement: paso 7, imagen 3 de 3
    • With the display laying on the keyboard, locate the black square panel marked in the photo.
    • Grab the side marked in photo #2 and pull it towards you peeling off the surrounding tape and releasing it from the actual display board.
    • This will then remove the connection between the display and the top cover.
Conclusión
4 personas más completaron esta guía.
MJ Routh
Miembro Desde 11/06/17
465 Reputación
3 Guías creadas
Equipo
Baylor, Team S8-G5, Johnson Fall 2017 Miembro de Baylor, Team S8-G5, Johnson Fall 2017
BU-JOHNSON-F17S8G5
3 Miembros
4 Guías creadas
2 comentarios
this guide is really bad, dangerous and should be removed !
at step 3 you crack and kill the existing display. If it was still somewhat working before now you are assured it is completely dead !
adrenochrome - Contestar
agreed, step 3 should use the opening tool on a top corner of the bezel, not against the screen. you just screwed up the screen if it worked at all
Hidden Djinn - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 7
Ultimos 30 días: 28
Todo El Tiempo: 3,559
