Saltar al contenido principal
HP Elitebook 8460p RAM (Random Access Memory) Replacement
Qué necesitas
  1. HP Elitebook 8460p RAM (Random Access Memory) Replacement, Battery: paso 1, imagen 1 de 1
    • On the back of the computer, slide the left switch towards the outside of the laptop until you hear a click.
  2. HP Elitebook 8460p RAM (Random Access Memory) Replacement: paso 2, imagen 1 de 1
    • Slide the battery away from the switches until it can be lifted away from the laptop.
    • Lift the battery away from the laptop.
  3. HP Elitebook 8460p RAM (Random Access Memory) Replacement, Back Panel: paso 3, imagen 1 de 1
    • On the back of the laptop, slide the right switch toward the outside of the laptop until you hear a click.
  4. HP Elitebook 8460p RAM (Random Access Memory) Replacement: paso 4, imagen 1 de 1
    • Slide the back shell of the laptop away from the switches until it can be lifted up.
    • Lift the shell straight up.
  5. HP Elitebook 8460p RAM (Random Access Memory) Replacement, RAM (Random Access Memory): paso 5, imagen 1 de 3 HP Elitebook 8460p RAM (Random Access Memory) Replacement, RAM (Random Access Memory): paso 5, imagen 2 de 3 HP Elitebook 8460p RAM (Random Access Memory) Replacement, RAM (Random Access Memory): paso 5, imagen 3 de 3
    • Attach ESD strap around your wrist and to a ground.
    • Using both thumbs, locate the two metal clips and pull them apart, allowing the RAM chip to pop upwards.
  6. HP Elitebook 8460p RAM (Random Access Memory) Replacement: paso 6, imagen 1 de 2 HP Elitebook 8460p RAM (Random Access Memory) Replacement: paso 6, imagen 2 de 2
    • Pull the RAM chip straight out and repeat for the second chip.
    • If installing new RAM chip(s), seat the chip firmly in the RAM slot and push down until the metal clips snap in place.
Conclusión
3 personas más completaron esta guía.
Un comentario
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 11
Ultimos 30 días: 35
Todo El Tiempo: 1,913
