Saltar al contenido principal
HP Elitebook 8460p Modem Card Replacement
Qué necesitas
  1. HP Elitebook 8460p Modem Card Replacement, Battery: paso 1, imagen 1 de 1
    • On the back of the computer, slide the left switch towards the outside of the laptop until you hear a click.
  2. HP Elitebook 8460p Modem Card Replacement: paso 2, imagen 1 de 1
    • Slide the battery away from the switches until it can be lifted away from the laptop.
    • Lift the battery away from the laptop.
  3. HP Elitebook 8460p Modem Card Replacement, Back Panel: paso 3, imagen 1 de 1
    • On the back of the laptop, slide the right switch toward the outside of the laptop until you hear a click.
  4. HP Elitebook 8460p Modem Card Replacement: paso 4, imagen 1 de 1
    • Slide the back shell of the laptop away from the switches until it can be lifted up.
    • Lift the shell straight up.
  5. HP Elitebook 8460p Modem Card Replacement, Modem Card: paso 5, imagen 1 de 2 HP Elitebook 8460p Modem Card Replacement, Modem Card: paso 5, imagen 2 de 2
    • Attach an ESD strap to your wrist and to a ground.
    • Using a Phillips #0 bit, remove the two 3.0 mm screws and set them off to the side side on a magnetic surface.
  6. HP Elitebook 8460p Modem Card Replacement: paso 6, imagen 1 de 2 HP Elitebook 8460p Modem Card Replacement: paso 6, imagen 2 de 2
    • Push down on one corner of the sound card and lift it straight up.
  7. HP Elitebook 8460p Modem Card Replacement: paso 7, imagen 1 de 2 HP Elitebook 8460p Modem Card Replacement: paso 7, imagen 2 de 2
    • Disconnect the wire plug by grasping the sound card in one hand and the wire in another and pulling them apart.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 14
Todo El Tiempo: 1,498
