Saltar al contenido principal
HP Elitebook 8460p Cooling Fan Replacement
Qué necesitas
  1. HP Elitebook 8460p Cooling Fan Replacement, Battery: paso 1, imagen 1 de 1
    • On the back of the computer, slide the left switch towards the outside of the laptop until you hear a click.
  2. HP Elitebook 8460p Cooling Fan Replacement: paso 2, imagen 1 de 1
    • Slide the battery away from the switches until it can be lifted away from the laptop.
    • Lift the battery away from the laptop.
  3. HP Elitebook 8460p Cooling Fan Replacement, Back Panel: paso 3, imagen 1 de 1
    • On the back of the laptop, slide the right switch toward the outside of the laptop until you hear a click.
  4. HP Elitebook 8460p Cooling Fan Replacement: paso 4, imagen 1 de 1
    • Slide the back shell of the laptop away from the switches until it can be lifted up.
    • Lift the shell straight up.
  5. HP Elitebook 8460p Cooling Fan Replacement, CPU Cooling Fan: paso 5, imagen 1 de 2 HP Elitebook 8460p Cooling Fan Replacement, CPU Cooling Fan: paso 5, imagen 2 de 2
    • Attach an ESD strap to your wrist and to a ground.
    • Using a Phillips #0 bit, unscrew the two screws on opposite corners of the fan.
  6. HP Elitebook 8460p Cooling Fan Replacement: paso 6, imagen 1 de 2 HP Elitebook 8460p Cooling Fan Replacement: paso 6, imagen 2 de 2
    • Pull the fan straight up and to the side slightly.
  7. HP Elitebook 8460p Cooling Fan Replacement: paso 7, imagen 1 de 2 HP Elitebook 8460p Cooling Fan Replacement: paso 7, imagen 2 de 2
    • Disconnect the small electrical connector. Pry the edge up with your finger nails or using a small plastic pry tool.
  8. HP Elitebook 8460p Cooling Fan Replacement: paso 8, imagen 1 de 1
    • Using a Phillips #0 bit, unscrew the six screws on the heat sink.
  9. HP Elitebook 8460p Cooling Fan Replacement: paso 9, imagen 1 de 2 HP Elitebook 8460p Cooling Fan Replacement: paso 9, imagen 2 de 2
    • Pry the inside edge up, pulling the entire assembly to the inside of the laptop, exposing the processor and graphics processor
    • Clean and replace the thermal paste on the processor if you have any thermal paste.
  10. HP Elitebook 8460p Cooling Fan Replacement: paso 10, imagen 1 de 1
    • Blow compressed air through the vent from the outside and through the heat sink.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 16
Ultimos 30 días: 45
Todo El Tiempo: 4,454
