Saltar al contenido principal
HP Elitebook 840 G1 Battery Replacement
Qué necesitas
  1. HP Elitebook 840 G1 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Slide the latch, to the right, away from the lock symbol.
    • Slide the cover away from the latch to remove it.
  2. HP Elitebook 840 G1 Battery Replacement: paso 2, imagen 1 de 1
    • Once the cover is removed you will be able to see the battery and the two latches that hold it in place.
    • The two latches should be pulled back, one of which is spring loaded and must be held in place in order to remove the battery.
  3. HP Elitebook 840 G1 Battery Replacement: paso 3, imagen 1 de 1
    • Battery should easily be lifted up and out.
Conclusión
26 personas más completaron esta guía.
Ashley Williams
Miembro Desde 08/27/15
2,398 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 5-3, Blackwell Fall 2015 Miembro de USF Tampa, Team 5-3, Blackwell Fall 2015
USFT-BLACKWELL-F15S5G3
4 Miembros
19 Guías creadas
2 comentarios
Where do I buy another battery and how long does it last on the laptop? 4hr or more?
Vikshay Vuthavadoo - Contestar
Passt auch für HP Elitebook 850 G2.
Die Anleitung und der Ersatzakku konnten auch bei einem HP Elitebook 850 G2 (Bezeichnung lt. Systeminfo des Notebooks) verwendet werden, das der Akku exakt der gleiche war (HP CM03)
Raller - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 7
Ultimos 7 días: 47
Ultimos 30 días: 247
Todo El Tiempo: 77,256
