Saltar al contenido principal
HP Elitebook 820 G2 RAM Replacement
  1. HP Elitebook 820 G2 RAM Replacement, Back Panel: paso 1, imagen 1 de 2 HP Elitebook 820 G2 RAM Replacement, Back Panel: paso 1, imagen 2 de 2
    • Slide the lever firmly to the left on the back panel.
    • Once the back panel is unlocked, there should be red showing to the right of the lever.
  2. HP Elitebook 820 G2 RAM Replacement: paso 2, imagen 1 de 2 HP Elitebook 820 G2 RAM Replacement: paso 2, imagen 2 de 2
    • Slide the back panel towards you.
    • Lift the back panel to remove it.
  3. HP Elitebook 820 G2 RAM Replacement, RAM: paso 3, imagen 1 de 1
    • Undo the clips on the sides of the RAM chips by pushing them away from the RAM.
    • Too much pressure might snap the clips.
  4. HP Elitebook 820 G2 RAM Replacement: paso 4, imagen 1 de 1
    • Once the clips are unfastened, use a plastic spudger to lightly pry up the RAM chips.
    • Grab the RAM chips, remove them, and set them aside.
Conclusión
Una persona más ha completado esta guía.
Un comentario
Hi KaitLyn Teubert
Thank you for your HP Elitebook 820 G2 RAM Replacement tutorial
Currently, I have 2 HP Elitebook 820 G2 notebook, and I have problem with one of my HP Elitebook 820 G2.
RAM is not detected. I have tried to replace the RAM to another HP Elitebook 820 G2, and also buy new RAM but its doesn't work at all.
May you have any suggestion to my problem?
Thank you.
Jaya Ma - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 31
Todo El Tiempo: 1,509
