Saltar al contenido principal
HP Elitebook 820 G2 Network Card Replacement
Qué necesitas
  1. HP Elitebook 820 G2 Network Card Replacement, Back Panel: paso 1, imagen 1 de 2 HP Elitebook 820 G2 Network Card Replacement, Back Panel: paso 1, imagen 2 de 2
    • Slide the lever firmly to the left on the back panel.
    • Once the back panel is unlocked, there should be red showing to the right of the lever.
  2. HP Elitebook 820 G2 Network Card Replacement: paso 2, imagen 1 de 2 HP Elitebook 820 G2 Network Card Replacement: paso 2, imagen 2 de 2
    • Slide the back panel towards you.
    • Lift the back panel to remove it.
  3. HP Elitebook 820 G2 Network Card Replacement, Network Card: paso 3, imagen 1 de 2 HP Elitebook 820 G2 Network Card Replacement, Network Card: paso 3, imagen 2 de 2
    • Use a Phillips #0 screwdriver to remove the 2 mm head screw on the side of the network card.
    • The card will pop up at an angle after the screw is removed like this.
  4. HP Elitebook 820 G2 Network Card Replacement: paso 4, imagen 1 de 1
    • After the screw is removed, the card can be wiggled back and forth while gently pulling backwards to take it out of its slot on the motherboard.
    • Disconnect the two leads on the other screw side of the card. You have now removed the network card.
    • The leads and their connections on the card are labeled.
Conclusión
To reassemble your device, follow these instructions in reverse order. Note, when replacing the connections on the network card, they must be plugged in to the correct connections. Both the cables from the motherboard and connections on the network card are labeled.
3 personas más completaron esta guía.
Un comentario
My HP 820 G2’s WiFi/Bluetooth card was working bit intermittently. Especially Bluetooth was reconnecting all the time with my speakers if I didn’t listen to music.
I didn’t find any information which WiFi/Bluetooth card might be a good choice to upgrade. I took a chance and just ordered Intel 9260NGW card. It seems to work fine after couple hours; don’t know how it’ll be in the long run. My original card was Intel 7265NGW.
NGW = NGFF = M.2 slot, source: https://www.dell.com/community/Laptops-G...
Juho Itä - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 43
Todo El Tiempo: 2,631
