Saltar al contenido principal
HP Elitebook 820 G1 RAM Replacement
Qué necesitas
  1. HP Elitebook 820 G1 RAM Replacement, Battery: paso 1, imagen 1 de 1
    • Ensure the laptop is completely powered off and power adapter is unplugged before removing the battery.
    • Turn over laptop so that the bottom is showing.
    • Unlock the latch.
  2. HP Elitebook 820 G1 RAM Replacement: paso 2, imagen 1 de 1
    • Remove the back cover and you will then be able to see the battery.
  3. HP Elitebook 820 G1 RAM Replacement: paso 3, imagen 1 de 1
    • Unlatch the two latches securing the battery in the case.
  4. HP Elitebook 820 G1 RAM Replacement: paso 4, imagen 1 de 1
    • Use a plastic opening tool to lift and remove the battery.
  5. HP Elitebook 820 G1 RAM Replacement, RAM: paso 5, imagen 1 de 1
    • Once the battery is removed from the device, slide both latches away from the RAM module with your fingers.
    • The latches are spring assisted and the RAM module will lift for removal.
Conclusión
2 personas más completaron esta guía.
Equipo
USF Tampa, Team S5-G1, Eyestone Spring 2018 Miembro de USF Tampa, Team S5-G1, Eyestone Spring 2018
USFT-EYESTONE-S18S5G1
3 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 16
Todo El Tiempo: 1,185
