Saltar al contenido principal
HP Elitebook 820 G1 Monitor Display Replacement
Qué necesitas
  1. HP Elitebook 820 G1 Monitor Display Replacement, Battery: paso 1, imagen 1 de 1
    • Ensure the laptop is completely powered off and power adapter is unplugged before removing the battery.
    • Turn over laptop so that the bottom is showing.
    • Unlock the latch.
  2. HP Elitebook 820 G1 Monitor Display Replacement: paso 2, imagen 1 de 1
    • Remove the back cover and you will then be able to see the battery.
  3. HP Elitebook 820 G1 Monitor Display Replacement: paso 3, imagen 1 de 1
    • Unlatch the two latches securing the battery in the case.
  4. HP Elitebook 820 G1 Monitor Display Replacement: paso 4, imagen 1 de 1
    • Use a plastic opening tool to lift and remove the battery.
  5. HP Elitebook 820 G1 Monitor Display Replacement, Fan: paso 5, imagen 1 de 1
    • Remove the hard drive by unscrewing the four 8mm screws with the T7 philip's head.
  6. HP Elitebook 820 G1 Monitor Display Replacement: paso 6, imagen 1 de 1
    • Pry off ten rubber paddings on the outer edge of the laptop to reveal the torx screws.
    • Unscrew the ten 8mm torx screws that are under the rubber paddings using the T7 tip torx screwdriver.
  7. HP Elitebook 820 G1 Monitor Display Replacement: paso 7, imagen 1 de 1
    • Remove the two 4mm screws indicated by the M2.5X4 using the J00 tip screwdriver.
    • Remove SD card cap by just sliding out to reveal one screw.
  8. HP Elitebook 820 G1 Monitor Display Replacement: paso 8, imagen 1 de 1
    • Remove the two 3mm screws indicated by the M2.03 using the J00 tip screwdriver.
    • Remove the 4mm SD card screw using the J00 tip.
  9. HP Elitebook 820 G1 Monitor Display Replacement: paso 9, imagen 1 de 1
    • Remove the one 4mm fan screw using the J00 tip screwdriver.
    • Remove screw and metal plate to expose ribbon cable connector.
  10. HP Elitebook 820 G1 Monitor Display Replacement: paso 10, imagen 1 de 1
    • Use an opening tool to pry up the ribbon connector to disconnect.
  11. HP Elitebook 820 G1 Monitor Display Replacement: paso 11, imagen 1 de 1
    • Turn laptop over back to normal position as shown in the image.
    • Use opening tools to pry up keyboard.
    • When prying up keyboard, be sure to start near any corner of the keyboard.
    • There are two ribbon cables that must be disconnected before fully removing keyboard.
  12. HP Elitebook 820 G1 Monitor Display Replacement: paso 12, imagen 1 de 3 HP Elitebook 820 G1 Monitor Display Replacement: paso 12, imagen 2 de 3 HP Elitebook 820 G1 Monitor Display Replacement: paso 12, imagen 3 de 3
    • Carefully lift keyboard on one side to expose the two ribbon cables.
    • Use an opening tool to lift up the locking clip and unplug the two ribbon cables.
  13. HP Elitebook 820 G1 Monitor Display Replacement: paso 13, imagen 1 de 1
    • Remove the two 4mm screws centered notated by the keyboard logo using the J00 tip.
  14. HP Elitebook 820 G1 Monitor Display Replacement: paso 14, imagen 1 de 3 HP Elitebook 820 G1 Monitor Display Replacement: paso 14, imagen 2 de 3 HP Elitebook 820 G1 Monitor Display Replacement: paso 14, imagen 3 de 3
    • Once keyboard has been fully removed, the system case containing the motherboard can be lifted out easily.
    • The display is connected to the shell of the laptop.
  15. HP Elitebook 820 G1 Monitor Display Replacement: paso 15, imagen 1 de 1
    • Unplug fan cable by pulling away from its connector.
  16. HP Elitebook 820 G1 Monitor Display Replacement: paso 16, imagen 1 de 1
    • Unscrew the two 6mm fan screws using the J00 tip.
    • Fan screws are encased in springs and cannot be removed.
  17. HP Elitebook 820 G1 Monitor Display Replacement, Monitor display: paso 17, imagen 1 de 1
    • Retrieve the monitor display connected to the plastic chassis.
  18. HP Elitebook 820 G1 Monitor Display Replacement: paso 18, imagen 1 de 1
    • Unscrew the two 4mm hinge screws using the Philips 00 tip screwdriver.
  19. HP Elitebook 820 G1 Monitor Display Replacement: paso 19, imagen 1 de 1
    • Unhinge the monitor display from the chassis.
Conclusión
Equipo
USF Tampa, Team S5-G1, Eyestone Spring 2018 Miembro de USF Tampa, Team S5-G1, Eyestone Spring 2018
USFT-EYESTONE-S18S5G1
3 Miembros
7 Guías creadas
Un comentario
Hello,
I need to replace the inverter as my screen is too much dark.
I cannot see the inverter and even I cannot find any inverter for this model.
Do you know how to access to this inverter? Is it embedded within the screen?
Thanks by advance.
BR
richard P - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 6
Ultimos 30 días: 24
Todo El Tiempo: 3,307
