Saltar al contenido principal
HP Elitebook 820 G1 Hard Drive Replacement
Qué necesitas
  1. HP Elitebook 820 G1 Hard Drive Replacement, Battery: paso 1, imagen 1 de 1
    • Ensure the laptop is completely powered off and power adapter is unplugged before removing the battery.
    • Turn over laptop so that the bottom is showing.
    • Unlock the latch.
  2. HP Elitebook 820 G1 Hard Drive Replacement: paso 2, imagen 1 de 1
    • Remove the back cover and you will then be able to see the battery.
  3. HP Elitebook 820 G1 Hard Drive Replacement: paso 3, imagen 1 de 1
    • Unlatch the two latches securing the battery in the case.
  4. HP Elitebook 820 G1 Hard Drive Replacement: paso 4, imagen 1 de 1
    • Use a plastic opening tool to lift and remove the battery.
  5. HP Elitebook 820 G1 Hard Drive Replacement, Hard Drive: paso 5, imagen 1 de 1
    • Remove the four 8mm screws with the T7 philip's head.
  6. HP Elitebook 820 G1 Hard Drive Replacement: paso 6, imagen 1 de 1
    • Remove the hard drive casing.
    • Unscrew the four 8mm Philips screws holding the hard drive.
  7. HP Elitebook 820 G1 Hard Drive Replacement: paso 7, imagen 1 de 1
    • Remove the hard drive from the casing and replace it.
Conclusión
3 personas más completaron esta guía.
Equipo
USF Tampa, Team S5-G1, Eyestone Spring 2018 Miembro de USF Tampa, Team S5-G1, Eyestone Spring 2018
USFT-EYESTONE-S18S5G1
3 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 32
Todo El Tiempo: 3,838
