Saltar al contenido principal
HP Elitebook 6930p RAM (Expansion Slot) Replacement
Qué necesitas
  1. HP Elitebook 6930p RAM (Expansion Slot) Replacement, Battery Removal: paso 1, imagen 1 de 3 HP Elitebook 6930p RAM (Expansion Slot) Replacement, Battery Removal: paso 1, imagen 2 de 3 HP Elitebook 6930p RAM (Expansion Slot) Replacement, Battery Removal: paso 1, imagen 3 de 3
    • Flip laptop over and locate the battery release button
    • Push release button to the left to release battery and gently pull battery from the laptop
  2. HP Elitebook 6930p RAM (Expansion Slot) Replacement, RAM (Expansion Slot): paso 2, imagen 1 de 2 HP Elitebook 6930p RAM (Expansion Slot) Replacement, RAM (Expansion Slot): paso 2, imagen 2 de 2
    • Locate the RAM expansion slot cover on the bottom of the laptop
    • Loosen the PM2.0×5.0 captive screw and remove the cover.
  3. HP Elitebook 6930p RAM (Expansion Slot) Replacement: paso 3, imagen 1 de 2 HP Elitebook 6930p RAM (Expansion Slot) Replacement: paso 3, imagen 2 de 2
    • Install RAM module into the RAM slot on an angle of around 30 degrees
    • Press the RAM module down with your fingers on each corner until it clicks into the 2 metal clips and is locked down
    • Check to ensure the metal tabs are holding the RAM module down on both sides
    • Reinstall the RAM cover
Conclusión
8 personas más completaron esta guía.
Richdave
Miembro Desde 04/09/10
32,051 Reputación
30 Guías creadas
Equipo
Master Techs Miembro de Master Techs
Community
322 Miembros
2,520 Guías creadas
17 comentarios
What kind of RAM do you place in this slot?
I want to upgrade my notebook, maybe with some RAM from ebay, so, What should I buy?
Jan Cerenohorsky - Contestar
Also, is there already any RAM by default? What is the maximum capacity you can upgrade to?
Jan Cerenohorsky -
Yes under the Keyboard and the Max is 8GB DDR2 6400
dcliddle - Contestar
Can you add an 8GB DDR2 6400 to your laptop (HP6930p) without upgrading or changing the factory installed one? The label on the bottom of mine says C2D P8700 2.53 GHz 4GB.
Thanks for any help!
Brian Fenech - Contestar
Thank you for information.
By p8slot.com
sutep Fifa - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 14
Ultimos 30 días: 38
Todo El Tiempo: 15,513
