Introducción
If the WI-FI on your HP Elitebook 2740p is not working properly it may be time to replace your WI-Fi card. This guide will go through the steps to replace it.
Qué necesitas
Place the laptop face down in front of you.
Use a Phillips #0 screwdriver to remove the three 3 mm screws from the back of the case.
Remove the back panel.
Casi Terminas!
Conclusión
