Saltar al contenido principal
HP ElitePad 900 Volume Control Buttons Replacement
Qué necesitas
  1. HP ElitePad 900 Volume Control Buttons Replacement, Front Panel Assembly: paso 1, imagen 1 de 1
    • Unscrew the two 2.8mm Phillips #000 screws near the power connector.
  2. HP ElitePad 900 Volume Control Buttons Replacement: paso 2, imagen 1 de 2 HP ElitePad 900 Volume Control Buttons Replacement: paso 2, imagen 2 de 2
    • Use a suction cup to pull the display assembly up.
  3. HP ElitePad 900 Volume Control Buttons Replacement: paso 3, imagen 1 de 2 HP ElitePad 900 Volume Control Buttons Replacement: paso 3, imagen 2 de 2
    • Use the tip of a spudger to disconnect the two display ZIF connectors.
  4. HP ElitePad 900 Volume Control Buttons Replacement, Volume Control Buttons: paso 4, imagen 1 de 3 HP ElitePad 900 Volume Control Buttons Replacement, Volume Control Buttons: paso 4, imagen 2 de 3 HP ElitePad 900 Volume Control Buttons Replacement, Volume Control Buttons: paso 4, imagen 3 de 3
    • Using the Phillips screwdriver remove the two 2.4mm #000 screws that are securing the volume control buttons to the device.
    • Lift up the silver panel, removing it completely from the device
    • Push the buttons through the slot to remove them from the device
Conclusión
Kyle Marques
Miembro Desde 09/03/15
889 Reputación
6 Guías creadas
Equipo
USF Tampa, Team 12-4, Blackwell Fall 2015 Miembro de USF Tampa, Team 12-4, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G4
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 673
