Saltar al contenido principal
HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement
Qué necesitas
  1. HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement, Hard Disk Drive / Solid State Drive: paso 1, imagen 1 de 3 HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement, Hard Disk Drive / Solid State Drive: paso 1, imagen 2 de 3 HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement, Hard Disk Drive / Solid State Drive: paso 1, imagen 3 de 3
    • Place the computer screen down on a flat surface.
    • Push the two locking latches to the unlocked position.
    • Push the cover toward the top of the computer and lift up.
  2. HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement: paso 2, imagen 1 de 3 HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement: paso 2, imagen 2 de 3 HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement: paso 2, imagen 3 de 3
    • Grasp the handle on the hard drive cage to the left of the stand. It is marked with green.
    • Pull the handle up, allowing the entire cage to slide toward the outward edge of the computer.
    • Pull the entire cage up and out of the device.
  3. HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement: paso 3, imagen 1 de 2 HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement: paso 3, imagen 2 de 2
    • Once the cage is out of the device, use a Torx T15 driver to unscrew the four 10mm screws keeping the drive in place. There are two screws on each side.
    • Once all the screws are removed, lift the drive out of the cage.
Conclusión
4 personas más completaron esta guía.
Equipo
Cal Poly, Team 1-24, Maness Fall 2015 Miembro de Cal Poly, Team 1-24, Maness Fall 2015
CPSU-MANESS-F15S1G24
4 Miembros
14 Guías creadas
2 comentarios
where can i buy a replace cage for the hard drive?
Thomas Dickson - Contestar
What replacement guide can I buy for my HP EliteOne 800 G1 all in one?
Hank Trujillo - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 10
Ultimos 30 días: 61
Todo El Tiempo: 8,325
