Saltar al contenido principal
HP EliteBook x360 830 G7 RAM Replacement
Qué necesitas
  1. HP EliteBook x360 830 G7 RAM Replacement, Remove the backplate: paso 1, imagen 1 de 2 HP EliteBook x360 830 G7 RAM Replacement, Remove the backplate: paso 1, imagen 2 de 2
    • Turn the computer over so the back is facing up.
    • Use a Torx T5 screwdriver to remove the three 9 mm screws from the hinge of the device.
    • Use a Torx T5 screwdriver to remove the two 7 mm screws from the left and right mid-section of the case.
    • Lift the backplate from the computer.
  2. HP EliteBook x360 830 G7 RAM Replacement, Remove the shield: paso 2, imagen 1 de 3 HP EliteBook x360 830 G7 RAM Replacement, Remove the shield: paso 2, imagen 2 de 3 HP EliteBook x360 830 G7 RAM Replacement, Remove the shield: paso 2, imagen 3 de 3
    • Gently lift the larger, rectangular metal shielding off. This shielding covers the RAM.
  3. HP EliteBook x360 830 G7 RAM Replacement, Remove the RAM: paso 3, imagen 1 de 1
    • Push down on the two latches on both sides of the RAM to release it.
    • This will allow you to remove the RAM and replace it with no issues.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 11
Ultimos 30 días: 72
Todo El Tiempo: 1,068
