Saltar al contenido principal
HP EliteBook x360 830 G5 M2 Solid State Drive Replacement
Qué necesitas
  1. HP EliteBook x360 830 G5 M2 Solid State Drive Replacement, Back Cover: paso 1, imagen 1 de 1
    • With the T5 screw-bit and screwdriver, loosen the five captive screws on the bottom of the laptop.
  2. HP EliteBook x360 830 G5 M2 Solid State Drive Replacement: paso 2, imagen 1 de 2 HP EliteBook x360 830 G5 M2 Solid State Drive Replacement: paso 2, imagen 2 de 2
    • With a spudger or opening tool, pry above the computer's hinges and separate the posterior edge and sides.
  3. HP EliteBook x360 830 G5 M2 Solid State Drive Replacement: paso 3, imagen 1 de 1
    • The back cover is held in place by magnetic strips.
    • Remove the battery.
  4. HP EliteBook x360 830 G5 M2 Solid State Drive Replacement, M.2 Solid State Drive: paso 4, imagen 1 de 1
    • Pull the tab attached to the M.2 solid state drive shield up.
  5. HP EliteBook x360 830 G5 M2 Solid State Drive Replacement: paso 5, imagen 1 de 1
    • With the Phillips #1 screwdriver, loosen the single screw that secures the M.2 solid state drive to the system board.
  6. HP EliteBook x360 830 G5 M2 Solid State Drive Replacement: paso 6, imagen 1 de 1
    • Once the springs release, carefully remove the M.2 solid state drive.
    • Pull the SSD card gently so you don't bend any pins.
Conclusión
Ashia Lewis
Miembro Desde 09/03/21
246 Reputación
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 16
Todo El Tiempo: 521
