Saltar al contenido principal
HP EliteBook x360 830 G5 Fan Replacement
Qué necesitas
  1. HP EliteBook x360 830 G5 Fan Replacement, Back Cover: paso 1, imagen 1 de 1
    • With the T5 screw-bit and screwdriver, loosen the five captive screws on the bottom of the laptop.
  2. HP EliteBook x360 830 G5 Fan Replacement: paso 2, imagen 1 de 2 HP EliteBook x360 830 G5 Fan Replacement: paso 2, imagen 2 de 2
    • With a spudger or opening tool, pry above the computer's hinges and separate the posterior edge and sides.
  3. HP EliteBook x360 830 G5 Fan Replacement: paso 3, imagen 1 de 1
    • The back cover is held in place by magnetic strips.
    • Remove the battery.
  4. HP EliteBook x360 830 G5 Fan Replacement, Fan: paso 4, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • With tweezers, pull back the retention tape that is attached to the fan cable.
  5. HP EliteBook x360 830 G5 Fan Replacement: paso 5, imagen 1 de 1
    • Use your fingers to carefully disconnect the fan cable from the motherboard.
  6. HP EliteBook x360 830 G5 Fan Replacement: paso 6, imagen 1 de 1
    • Using a Phillips #1 screwdriver, loosen the three screws that secure the fan to the motherboard.
  7. HP EliteBook x360 830 G5 Fan Replacement: paso 7, imagen 1 de 1
    • With two fingers, carefully lift the left edge of the fan and remove it from the board.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 14
Todo El Tiempo: 346
